samual theres no way that system uses over 700 watts. u prob bought a 30 dollar 700 watt psu or somthing. 10 hds isnt that many watts... prob similar to having a second 7800gtx... and burning 2 700 watts combined (which i dont even think u can do) is nearly impossible, maybe if u tried quad 7800gtx 10 750gb harddrives 4 dvd drives and dual opterons overclocked to 3.0 then ud get close to 1400 watts... the point is, i dont believe u.
WHAT ! :? First of all who said that my system uses up 700w? Care to answer ?
I said that I used 2x700w psu's, when did I ever say that my system uses 700w of power or even worse 1400w! I said that if I got 700 real watts from this setup it would be enough for me... oh wait .... maybe i should of said
more than enough ..... oh please forgive me o great one, i left out the one word that would of changed the course of history and would of prevented the universe from imploding.
if you actually read the entire thread you would see that i listed my rig. The entire setup might use up a maximum of 400-500w under full load if not less.
The main thing is someone asked a question about having enough power, my answer is simple and economic, instead of buying a expensive psu which offers you for ex. 700w of peak load power for 100$, you can achieve the same performance or more for much less by combining 2 or more cheaper psu's, but of course there are some factors to take into consideration, here are two that i can think of:
1. make sure that the cheap psu your buying is of good or decent quality (it doesn’t have to be from a famous company or certain model to be considered good quality), just dont buy it because its cheap
2. usually cheaper psu's leave out important info like real wattage, so you'll have to do some research.
if there are more things feel free to say
in the end you will have the much needed power and more just in case you need it, and still have some money leftover.
Finally, what does believing have
anything to do with what i have been saying, looks like you were on the weed this time you posted, am i trying to get anybody here to believe in something, am i preaching the word of god here, am i trying to sell you this new and improved vacuum cleaner :roll:
