OK so at Idle the CPU runs at 64C and at Load it gets to 70C. Here are my system specs.
Pentium D805 2.66ghz Stock
Asus P5WD2 Premium Motherboard
ATi Radeon X1800XT 512MB
1Gig OCZ Ram
I'm using an aftermarket cooler (Gigabyte Rocket Pro) that I bought off of newegg and it performs just as good as the Zalman fan everyone talks about. My gigabyte cooler was used on my old P43.0ghz and kept it to max load of 34C, so I know it works good. I applied a new coating of thermal paste to the Pentium D805 chip I recently bought when I recieved it from newegg and cleaned my Gigabyte Rocket Pro of all the old thermal paste and attached it to the new processor. I'm also gonna add I put a very thin layer of the thermal paste. The heatsink is sitting on the board and processor very tightly and is on correctly and is running at roughly 4200RPMs. SO WHY AM I STILL GETTING THESE REDICULOUSLY HOT TEMPERATURES??
What I will add and what my thoughts to the what the problem could be is that I am using VANTEC THERMAL PASTE as it is the only paste I have in my home and there are no computer shops where I live. This VANTEC THERMAL PASTE I'm using is what was leftover from my aftermarket cooling kit I installed on my old ATi Radeon 9800Pro. I believe this Paste may be crap because my beliefs are that it is restricting flow of heat to the heatsink because when I put my hand on the heatsink while the pc is on and under full load (Running FEAR) at 70degrees Celcius, my hand doesnt get burnt and the heatsink does not feel hot at all. Now i know the heatsink is doing something because if it wasn't the computer would automatically shutoff after a few seconds of overheating of the CPU, but i believe this VANTEC THERMAL PASTE is not allowing enough heat to move to the heatsink like ARCTIC SILVER 5 could.
Any thoughts/suggestions would be great. Thanks!
1Gig OCZ Ram
