1: Is it better to have a larger reservior eg... better to have 1 litre reservior than to have 0.5 litre reservior?
2: Is it better to have tubes that are as wide as possible or tubes that are as thin as possilbe? (internal dimensions)
3: Once the liquid cooling system is full of water how do I drain all the water out?
4: If I have water cooling set up in a tower case (Lian Li PC V 1000) Will the water cooling system still work if the case is put on its side??
5: Im still looking for single slot GPU water block for my SLI set up... Does this exist yet??
Thanks in advance.....
