I have the Thermaltake Armor case and the Asus AM2 M2N32 Wireless Mobo. I'm having a hard time trying to figure where the plugs go on the Mobo. The USB are in a 4 Pin block and doesn't line up right (I think). Can I boot it up and just test it or would that damage something? What is the best way to change the pin configuration (Cut the wires) :?: ? Anyone have the same setup? Also the case has two usb ports and the mobo only has one to plug into. Anything that can be done there? The audio has two pins labled Return do I plug those into NC? What is NC?
Thanks all
Thanks all
