Alright, so here is my quandry...
I have an Antec SLK-2650 Case, built an Intel machine (my first, I'm normally an AMD guy) off of a retail bundle I got for cheap direct from Intel.
So I build it, and I have my 120mm rear case fan sucking in cool air. I have a 80mm case fan in the front sucking in cool air. The 120 is quite a bit higher (right under PSU) and the 80 is at the bottom of the front.
Now, I also have one of those sleeve things that extends and goes to the heatsink fan, which I put another fan to keep sucking the air to keep it going out faster, as well as to pull some more of the hot air out of the case. As I type this, my CPU temp is around 65C...which I would think is running too hot. Full load gets it to between 70-75C. It has only restarted or frozen up on me a few times when I built it (not enough thermal compound), but I don't like the thing running too hot.
I have the stock Intel Heatsink/fan on a Pentium D 820, 2GB PC4200, 4HDD(Which are probably generating most of my heat, and only have a fan below them, nowhere else) and 2 optical drives, and a Radeon 1300Pro.
Anyone got any clues as to if this is too hot, and if so, what I should do to get the temp lower?
