Hope you guys can help cos im stuck on this one.
I have recently had a few problems with a dvd writer in that it wouldnt eject the disc that was in it, its been getting worse and it was interferring with windows, opening/closing all the time or at least trying too.
Anyway what i did was pop the side off and take out the voltage to the drive. The drive was the master on the 2nd IDE channel.
Since doing this all my drives are having giving me this problem. When i click on them in my computer to open them up there is a 3-4 sec delay before they open, it also applies to the folders too and files opening.
What did i do !! ive even replaced the master with a maxtor 120 gig HD and that aint solved it. Ive looked in the bios and all the drives read right.
Is there anything i can do in XP to check why its doing this. Im hoping you guys can come up with a fix to my problem.
I will endeavour to answer any question you need the answer too to help solve my little screw up
Cheers
Dokman
Cheers
Dokman
