logging on problem with XP Pro
Archived from groups: microsoft.public.windowsxp.basics (More info?)
When my song logs on he enters his password and his
desktop comes up and then automatically logs off. Any
suggestions?
6 answers Last reply
More about logging problem
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    "Jan" <cairnes@bellsouth.net> wrote in message
    news:3bda01c4a4c1$7428a280$a401280a@phx.gbl...
    > suggestions?
    Can you log on with other accounts on that computer? If so, then there's
    something in his profile that's corrupt, or something that he's got set to
    load at startup that isn't working right.
    Can he start in Safe Mode? If so, he can start disabling startup items until
    he figures out which one is causing the problem. Checking the event log
    would also be helpful.
    If none of the users can log in, and none can start in Safe Mode, have you
    tried Last Known Good from the same menu that gives you safe mode?
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    >-----Original Message-----
    >> suggestions?
    so, then there's
    startup items until
    the event log
    Safe Mode, have you
    safe mode?
    >His is the only profile on the computer. He cannot start
    in Safe Mode - it does the same thing. He has run the Last
    Know Good from the same menu and it did not correct the
    problem. Thank you for the reply and please pass along any
    other thoughts you have.
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    <anonymous@discussions.microsoft.com> wrote in message
    news:3ebc01c4a4e3$fead2cb0$a401280a@phx.gbl...
    >>> suggestions?
    > so, then there's
    > startup items until
    > the event log
    > Safe Mode, have you
    > safe mode?
    Does it start to log on, then go directly to "saving settings"?
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    >>>> suggestions?
    >> so, then there's
    >> startup items until
    Checking
    >> the event log
    >> Safe Mode, have you
    >> safe mode?
    Last
    any
    settings"?
    >YES, it does go directly to "saving settings"
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    news:264a01c4a4ee$33f87870$a501280a@phx.gbl...
    >>>>> suggestions?
    >>> so, then there's
    >>> startup items until
    > Checking
    >>> the event log
    >>> Safe Mode, have you
    >>> safe mode?
    > Last
    > any
    > settings"?
    Okay, you've removed and/or disabled some spyware, but the line that starts
    the spyware is still there.
    You need to boot into the recovery console with the XP CD. Choose "R" for
    repair when it asks.
    type this at the C prompt:
    copy C:\windows\system32\userinit.exe C:\windows\system32\wsaupdater.exe
    then restart the system. You should be able to log on.
    Then you need to edit the line in the registry that's looking for the
    spyware.
    Go to Start, Run, and type regedit.
    Go to :
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    Look for Userinit
    it's supposed to read:
    C:\WINDOWS\system32\userinit.exe
    So whatever else is there, fix it.
    then make sure that you run whatever spyware removers and antivirus programs
    that you have.
    Good luck.
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hi Jan,
    Run a spyware cleaner lately? The userinit value may have been corrupted by
    the removal of blazefind. It adds wsaupdater.exe to the logon value in the
    system registry, sometimes appending it, sometimes replacing it. Running
    Adaware or other cleaners detects and removes wsaupdater.exe, but doesn't
    correct the registry damage. If this is the case, then you may need to load
    the registry hive from another installation and change it. This is the key:
    Userinit string value should be:
    C:\WINDOWS\system32\userinit.exe,
    On the damaged installations it's one of these:
    C:\WINDOWS\system32\wsaupdater.exe,
    C:\WINDOWS\system32\userinit.exe,C:\WINDOWS\system32\wsaupdater.exe,
    Another "quickie" method of resolution is to load the Recovery Console (see
    below), copy userinit.exe as wsaupdater.exe from the command prompt, then
    restart normally. Once in, go and change the registry value back to what
    it's supposed to be and delete the copied file. To do this, use these
    commands:
    C:\Windows>
    C:\Windows>copy C:\Windows\system32\userinit.exe
    C:\Windows\system32\wsaupdater.exe
    Then you can exit once completed.
    HOW TO: Install and Use the Recovery Console in Windows XP [Q307654]
    http://support.microsoft.com/?kbid=307654
    This can also be done by using the 6 disk boot floppy set mentioned in the
    above article, as it loads enough of the Recovery Console so that you can
    copy the file. This is particularly useful if you have an OEM installation
    that includes only a Restore CD, or no disk at all.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Associate Expert - WindowsXP Expert Zone
    www.microsoft.com/windowsxp/expertzone
    Windows help - www.rickrogers.org
    > suggestions?
Desktops Microsoft Windows XP
