A8N SLI - Premium / RAM Problem
  • Motherboards
  • RAM
  • Computer
  • Overclocking
June 26, 2006 2:38:54 AM
Hey Everyone
I am new to these forums and this computer is my first build, so please excuse this problem if it seems trivial.
Problem: I originally built my computer with 1Gig RAM. Recently I purchased another, identical gig for my computer (Corsair XMS 3200 CMX 2X512). However when both gigs are inserted, my computer will not start. I assume this is a BIOS problem?
I checked and all of the sticks of RAM are operable, and none of the slots are damaged either (by putting one in at a time, etc).
please help!
eric
More about : a8n sli premium ram problem
June 26, 2006 8:15:24 AM
Looks like your board doesn't automatically reduce the ram speed to 333mhz. You can't run 4 double-sided sticks at 400mhz 1T on any of the athlon 64 cores.
Venice and San Diego cores can run 4 double-sided sticks at 400mhz 2T, previous cores can't run these at 400mhz at all.
Try this:
Put in one pair of the ram, enter bios, set the command rate to 2T and ddr speed to 333mhz. Then we can adjust the speed from there.
June 26, 2006 10:49:01 PM
I went into my BIOS. BIOS is automatically set at 333Mhz anyhow. Any other ideas out there?
June 28, 2006 6:32:18 PM
Are the sticks in dimm_a1 and dimm_b1?
