MacBook Pro Wireless Problem No air card installed or turn on
How to turn on wireless on MacBook pro it says no airport card is installed and sometime it tells me to turn on air card.
8 answers Last reply
More about macbook wireless problem card installed turn
  1. Is there a switch on it somewhere? Or maybe hot-keys?
    Hmmm, I never have that issue with my MSI Windows laptop...
  2. Were would they be?
  3. Never seen a Macbook pro with an external wifi switch, is it a new macbook pro air?
  4. On my dell laptop it is f2, I freaking hate that button.
    No its a macbook pro 2008
  6. What version of Mac OSX do you have? Did it just start happening recently? You can turn your wifi on and off at anytime in your network options in system preferences. When you open your network preferences(in system preferences) make sure your wifi is at the top of the list on the left. If you get the internet connected but then it stops working on you go into your console. You can get there from the finder menu by going to go--->utilites--->console. Look for logs around that time dealing with your network and post them if you can.
    The air card symbol is at the top right hand side but does not work it says missing air card
    Go to your network utility and see if the airport is listed in the drop down menu under the info tab. To get to the network utility go to (go----->utilities----network utility). If there is no airport/wifi showing up in that utility you will probably have to send it in to be fixed. Also maybe a fresh install of OSX might help.
Macbook Pro Wireless Mac OS X
