problem with laptop power, doesn't switch on
  • Power Supplies
  • Laptops
  • Power
  • LED Monitor
  • Components
Last response: in Components
June 28, 2006 8:39:20 AM
Hi,
My laptop has suddenly stopped accepting power. Here are the symptoms:
-- When i plug in the power cable into AC (without connecting to laptop). the LED in adapter glows. When I connect to the laptop the LED in adapter goes off. The laptop does start and it does not charge the battery either.
I have verified that its not a problem with power adapter by using it on other laptop and also using other laptops adapter with this one.
It is not a problem with laptop booting up also, because the laptop still works properly when I put a charged battery in it.
I have opened the laptop and cleaned everything so that no short circuit occurs.
Doe anyone have any ideas about what I can do next?
thanks !
More about : problem laptop power switch
June 28, 2006 6:44:41 PM
this is mainly a desktop forum, since laptops are tightly packed not many (if any) of us know much about the internals of a laptop. My suggestion is to talk to the manufacturer of ur laptop, i doubt u'll get any help here.
