Right, im experiencing a very frustrating problem with my soundcard. Just to explain the setup im using first...
I have my laptops optical s/pdif output connected to my minidisk deck. Im using its "monitor" function, which basically makes it work as a DAC. It takes in the spdif, outputs it to the anlogue line outs which are then connected up to my amp... The laptop has a Via Vinyl audio chip, the VT1618, and im using the latest driver available from the system mtfr, version 6.14.1.4130.
The problem is that there is a momentary.. about 0.5s moment between when a sound begins on the computer, and when sound is actualy output. The sound is NOT delayed, the first 0.5s is simply cut off. This happens all the time, whenever i go from silence > making a sound. So, for example the short pling sound that the windows volume control makes when you pling is simply never comes out (or occasionally i catch the tail end of it), the click noise explorer makes as you navigate is to short, and i never hear that either. When playing a track of music, again, the first 0.5s is simply cut. This makes it completely usueless for audio editing, and similar tasks.
Interestingly however, things work fine as long as something is playing in the background. For example, if i play a clip in wmp, and mute the sound in there, then play my music in itunes as usual, everything works fine. Sounds come out instantly, no problems. The same thing works with various other programs... ie. if i play some music, the windows volume control plinger then works. Quicktime is an interesting exception. Simply opening that (not playing anything) and leaving it in the background, everything works just fine. That is not a suitable solution to the problem. Leaving random programs open just to keep sound working properly is ridiculous.
The problem seems to be that whenever the machine goes from silent to a sound, it causes the spdif output to glitch or momentarily turn off which causes the minidisk deck to loose lock, and take that fraction of a sec to re-synch. I conclude this because when the minisdisk deck is recieveing a signal its display reads "Monitor" if it looses the signal is reads "digital; in unlock". When the computer is playin no sound is says "Monitor" after the computers booted and the spdif turns on. But as soon as i play a track for example, the display brifly flickers to "digital in unlock", resynchs, then back to "monitor"
I have searched around a great deal looking for a solution, iv found a number of people mention the problem, but most people just seem to assume its normal and put up with it, and no one has mentioned a solution, anywhere.
Thanks in advance
Thanks in advance
