I was fixing my old gamer, the one I gave to my wife about 2 days ago. S754 Sempron, 1gb of ram (G.Skill and mushkin), 20Gb + 120GB hdd, 9700pro Video card, Asus K8N-E deluxe. (NF3 250). Didn't bother deleting her old OS on the 20GB drive. Just ran the install over it so that it worked. It did, but it was buggy as sh!t. She couldn't run yahoo messenger, so as a test, I tried installing windows 2000 on the 120GB. Yahoo pager had several problems running on this install too, but it worked fine as soon as I installed all the updates for win2000. (requires .net?) It still had the problem of not being able to download things from IE, so I thought I'd try a PCI NIC, instead of the NF3's onboard.
This is where everything went to hell. After shutting the PC off, I plugged in the ancient 3com 3c905, and powered it back up. When you boot, instead of being asked which windows to load, it gives you the error message "error loading opterating system." Both harddrives are found in the bios. I can't use an old bootdisk, as the A drive in this system died awhile ago. (I'll look in the parts bin) I'm download Kinoppix tonight. I also tried to boot from the windows cd, but it now hangs on starting windows2000.
I fail to understand why trying to install this NIC would cause this. I don't think its the dual boot, many people have done this, and I rebooted several times before adding the card. The power was off, and I'm stumped. Please shout out ideas.
