I'm hoping somebody could give me a few ideas to improve my situation. Heres the story:
I've got a Leadtek 7900GT fitted with a Koolance water block (the one that covers the core and memory(ish)). It never goes above 46C. It was overclocking quite nicely and I had it on 500Mhz core and 700Mhz memory. Had no artifacts or anything so I decided to try 10Mhz more on core and memory and it crashed after one of the CPU tests on 3dmark. The monitors kept flicking on and off like when it changes resolution and the screen was garbled.
So, I reduced back to where I was stable before and it still wouldn't bench. I reset to default and it's completly stable, but if I now try to overclock either core or memory by even 5Mhz the machine will lock up or I'll get an error saying the nvidia driver has crashed.
I've tried reinstalling the driver by doing add/remove programs to get rid of the old one first to no effect.
Any ideas? Could it be a software issue or have I damaged something on the card and should give up while it's still working?
Any advice would be appreciated.
Cheers
Cheers
