SSD - The Performance Upgrade of the Future
Archived from groups: comp.dcom.voice-over-ip (More info?)
Hello, I have the following setup : Linphone --> SER --> c5300 --> POTS - Linphone : SIP softphone - SER : SIP Proxy/Registrar - c5300 : Cisco 5300 GW I have the "no ringback tone" problem when I call from the Linphone to the PSTN. The c5300 terminates the call (SIP->POTS) (PRI conx with Telco). My conf on c5300 for call termination :- ! dial-peer voice 1001 pots destination-pattern 210....... no digit-strip port 0 ! I used also the following commands on pots dial-peer with no success. progress_ind setup enable 3 progress_ind connect enable 8 any ideas ? thank you, Kostas
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
