machine 1:
standard case
stock cooler
cpu pentium d 940
motherboard asus p5nd2 sli
stock psu
machine 2:
thermaltake shark case
zalman 7700 alcu cooler
cpu pentium d 940
motherboard asus p5wd2
lc power green power 560w psu
The problem is that machine2 reports cpu temps of 42º in idle, and the machine1 reports 35º.
Does anyone haves an explanation for this? The cpu has been changed, to see if it was the problem, because with the other d940 the temp was 50º.
I'm betting that the problem is on the MB, what do you say about trading my P5WD2 for the P5ND2?? the 1st has a intel 955 and the second has a nvidia nforce4.
Thanks for helping.
standard case
stock cooler
cpu pentium d 940
stock psu
machine 2:
cpu pentium d 940
Thanks for helping.
