M mikehayez Distinguished Jul 1, 2006 2 0 18,510 Jul 1, 2006 #1 If a case is listed as ATX compatible can it accept micro-atx motherboards also? The case in question is the COOLMAX CS-470 and can be found here: Thank you for your help.
pengwin Distinguished Feb 25, 2006 2,800 1 20,780 Jul 1, 2006 #2 dont buy that case, sucks ass. .6mm is paper thin, i can break that case with my pinky. get these http://www.newegg.com/Product/Product.asp?Item=N82E16811119094 http://www.newegg.com/Product/Product.asp?Item=N82E16811119104 http://www.newegg.com/Product/Product.asp?Item=N82E16811119106 http://www.newegg.com/Product/Product.asp?Item=N82E16811119090 http://www.newegg.com/Product/Product.asp?Item=N82E16811119075 http://www.newegg.com/Product/Product.asp?Item=N82E16811119077 http://www.newegg.com/Product/Product.asp?Item=N82E16811119047 http://www.newegg.com/Product/Product.asp?Item=N82E16811119068 one of those.
M mikehayez Distinguished Jul 1, 2006 2 0 18,510 Jul 1, 2006 #3 But would a case listed as ATX compatible also be micro-atx compatible? That is my real question.
pengwin Distinguished Feb 25, 2006 2,800 1 20,780 Jul 1, 2006 #4 oh, hehe, depends. if it ha smounting holes for a mAtx mobo then yes if not then no.
