P5N32 SLI deluxe + water cooling + mod for SB.....
http://img109.imageshack.us/img109/9012/picture0089jw.th.jpg
For pplz who wish to have this MB and also wish to have Lian Li it is possible!
The fact that the heat pipes dont work very well upside down should not deter you from getting this MB into a Lian Li
You will just have to mod the MB a little.....
An old intel HSF (240 grams in total) has been cut to order and is now fitted ontop of the SB with room for SLI....
NB there is also a 120mm Panflo fan on the top of the case cooling the GPU and SB.
1 answer Last reply
More about p5n32 deluxe water cooling
  1. Nice rig...got that mobo...but I have a problem with mine...
Asus Water Cooling SLI Motherboards
