IPAQ SD Problem
Forum Smartphones & PDAs : Windows Mobile - IPAQ SD Problem
Archived from groups: microsoft.public.pocketpc (More info?)
I'm using Pocket PC 2002 on an HP IPAQ 3955. I have 2 SD cards (128 and
256) Suddenly, for no apparent reason, the IPAQ doesnt "see" the cards.
Any thoughts/Ideas/Suggestions welcome
Brian Abbishaw
Sponsored Links
> Brian Abbishaw
Have you tried a soft reset?
Nikki
Reply to Anonymous
- 0 +
> Brian Abbishaw
Just keep reinserting it and it will eventually pick it up. I have that
problem with mmc cards.
Marc
See http://www.imarc.co.uk/ for contact details.
Reply to marc
Make sure there is no pocket lint, or other debris, in the slot.
Bill Crocker
"Brian Abbishaw" <b.abbishaw@gmail.com> wrote in message
news:OFPdwT41EHA.3324@tk2msftngp13.phx.gbl...
> Brian Abbishaw
Reply to Anonymous
many "older" units, have issues with this, the contacts in the sd slot do
not hold the card as securely as they used to and as the ipaq gets bumped
around the card looses contact. the common work around seems to be to put a
piece of scotch (cello) tape or a piece of self adhesive mailing label on
the bottom, back side of the card. this makes the card thicker and thus
holds in place better. BE ADVISED: do this at your own risk, as it would
be quite a mess if a piece if the tape came off down in the SD slot, however
I have been doing this for close to a year now with 2 or 3 different cards
and haven't had any problems.
| Brian Abbishaw
Reply to Anonymous
- 0 +
I find the case it came with stops any bumps getting through. Annoying
that when switched off, a press on the unit will switch it on by making
it think the sd card had just been inserted.
Marc
Reply to marc
Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > IPAQ SD Problem
There are 1262 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
