Hey everyone; I thank you in advance for your time and help. I have built a new computer for my parents with the following parts:
* AMD Athlon 64 3200+ Venice 2000MHz HT 512KB L2 Cache Socket 939 Processor - Retail
http://www.newegg.com/Product/Produc...82E16819103535
* ASUS A8N-VM Socket 939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Produc...82E16813131571
* (2) G.SKILL 512MB 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) System Memory
http://www.newegg.com/Product/Produc...82E16820231078
* Computer Case - Retail
http://www.newegg.com/Product/Produc...82E16811103004
* 350 Watt PSU
http://www.newegg.com/Product/Produc...82E16817103012
* 250 GB Sata HDD
http://www.newegg.com/Product/Produc...82E16822144701
* DVD-RW
http://www.newegg.com/Product/Produc...82E16827106023
* DVD rom
http://www.newegg.com/Product/Produc...82E16827131409
This is my second build and I never had ANY problems with my first. Well with this one, everything seemed to go OK while installing XP SP2. When the installation of the OS was finished it seemed to take a long time to just bring up the "profiles" and then quite a while to load the desktop. By quite a while I mean literally at least 70 - 80 seconds. So once I got to the desktop of XP I put in the ASUS CD-rom to start installing some of the drivers like VGA and stuff like that. Well when I tried to open the cd via "my computer" it just hung, quite responding. I went to Task Manager and ended the unresponsive "my computer". Well then my entire desktop went away, all of the icons, start menu and stuff. So I killed explorer and restarted the task. It took over 4 minutes to bring back up my desktop!! I know that this is not normal. I know a 2 GHz is not lighting fast but I know a new load with nothing is faster than that. The same type of things continued after doing a hard boot. Just stopped responding on normal little things. I finally reinstalled XP 2 times and continue to get the same type of problems. The system just hangs, stops responding for no reason!! Any ideas what could be wrong?? I’m thinking the board may be bad but I’m not sure. What can/should I do???
Thanks for your help!!
* 350 Watt PSU
* 250 GB Sata HDD
* DVD-RW
* DVD rom
