Hi
I was overclocking my MSI 6337LE5. My Pentium III is a 1.4Ghz processor. I overclocked it to 1.51Ghz. I didnt increase voltage or anything. Didnt touch the Ram setting or nothing. Everything was alright but after two (2) hours my computer just went off and doesnt want to turn on.
Is rare because those two hours I played Counter Strike condition Zero and Doom 3. Plus I restarted and use windows XP again.
If my system would have overheated, dont you think it would have turn off by like 30 mins or 1 hour? or even less! It went off right in the middle of a counter strike condition zero. I played for like 30 minutes already before it went off.
I have taken out the battery, check the power supply, the power supply cable, the ATX connector and nothing. When my computer went off, it was the only thing to turn off because my monitor and speakers didnt turn off.
The only thing that happens when I press the "turn on" button in my case is the processor fan starts moving for 1 sec then goes off (and some neons that I have on my case). Also I check the processor, Is not burned. I change the processor, nothing.
Dont you think if something would have been burned, I would see the smoke or smell it? Nothing smells burned! I dont know whats going on!
Three hours before the shut down I updated the BIOS but my mobo was working correctly. After 1 hour I overclocked my processor to 1.51Ghz and after 2 hours my mobo went off. How did it went off after 2 hours? It was working correctly for those two hours! I dont think is the processor maybe the motherboard or something I dont know what can be.
Could you guys help me out?
