New here, hopefully someone can help me out, i am fairly decnt with computers although I have no formal training so when I run into technical problems i need some input.
My computer recently died(e-machines :roll: ), when i went to turn it on I had nothing no power no LED's nothing. So a friend of mine said to try replacing the power supply, so i took a 300w PS i had out of a new case I had laying around and installed that and when i turned it on the led's lit up for a few seconds but nothing booted. Then when i tried to turn it back on again I get nothing. So I guess that the motherboard was fried and now two power supplies are fried???
Next step ordered a new power supply and a new motherboard, 300w PS and a Asus P4S8X-MX Motherboard. OK so i get everything installed, pretty much just replaced the motherboard and power supply and hooked existing hard drive, cd-rom, processor (2.6ghz Intel celeron) etc. back up to new power supply, then boot up run through the BIOS and try to run windows and this where my "new" problems start I get the message about windows XP being improperly shut down and how do I want to start windows, safe mode, safe mode with networking, command prompt, last known configuration, or start windows normally. I have tried each of these options and none of them work it just restarts the computer and I get the same screen about windows not shutting down properly. Windows will not start.
So where do i go from here, did i do something wrong? Is my hard drive toast? Is my processor toast? Or am i forgetting something. One other thing in BIOS its recognizing all my drives and processor properly and everything seems to be configured OK. Any input would greatly apprieciated thanks.
