News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Intel forecast to cut P4 price by up to 34%
Published on July 08, 2004
Intel will trim its Pentium 4 and Celeron D prices on 22 August, Taiwanese mobo maker sources have claimed, ahead of the anticipated launch of the 3.8 GHz Pentium 4 570. Read more
Mobo makers facing component shortages
Published on July 29, 2005
Motherboard makers are facing component shortages that may threaten their business during the high season in the second half of the year, industry sources said. Read more
Mobo shipments to drop 5-15 percent in 2Q
Published on April 26, 2005
First-tier motherboard makers Asustek Computer, Elitegroup Computers (ECS) and Gigabyte Technology expect their second quarter's shipments to fall 5-15 percent on quarter, according to the companies. Read more
Latest Reviews & Articles
Efficiency: Core 2 Nukes Atom On The Desktop
Published on November 21, 2008
Atom is geared for low-cost, low-power netbooks and nettops, while the device is a poor choice for desktop PC applications. We show you why Core 2 is better, and give some guidance on how to pick the best power supply for your low-power application. Read more
Radeon HD 4870 X2: Four Cards Compared
Published on November 19, 2008
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Published on November 18, 2008
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
The Hardware Behind Overdrive
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
  Tom's Hardware Forums » Motherboards & Memory » General Motherboard » okay, PSU or mobo problem?
Word :   Username :
Bottom
Author
 Thread : okay, PSU or mobo problem?
Profile: stranger
More Information
my old emachine's (c2480) PSU got messed up so i replaced the PSU and i got no post. i replaced the motherboard later and it did post. after installing windows, i had to shut down the computer because i had something else to do. when i try turning on the pc later, i get no post with the new motherboard.
did the new PSU fry my new mobo or did my new mobo just die?
i'm confused and frustrated :evil:
if it helps:
athlon xp 2400+
1 x 512mb pc2100 samsung RAM
new mobo: http://www.newegg.com/Product/Prod [...] 6813186029
aspire 420watt psu
note that fans spin, hdd light comes on, optical drives eject, and i get no beeps. i just get no post. also, the monitor DOES work because i tried it with my other pc AND it doesn't post with both onboard video and from a video card. any help would be appreciated.
Related Product
Profile: newbie
More Information
You might of fried the motherboard. I did it once without knowing, did you put the system together while wearing socks or on carpet? =[
Profile: member
More Information
In the past i've found out that the EMachines blew their psu all the time and many times the mb went with it.
What it sounds like to me is that the motherboard is bad.
If you dont get a post or anything on the screen then that would be my first guess for the fact that it's a lot easier to mess up a mb when installing it then it is to kill a psu.
Profile: Ancient Poster
More Information
I would unplug the power supply and remove the atx 20 pin connector to reset the power. If you still can't post, try removing the board battery for about 1 minute.
Profile: stranger
More Information
i removed the battery and plugs from the psu for 24 hours. still no post. i guess i fried my motherboard AGAIN! so i'll have to buy another one AGAIN! :cry:
Google Ads
