I just ordered all the parts for my new system and got it all built without much going wrong, however when I turned on the power I found something indeed was. The system powered up, fans were spinning, onboard LED and case LED was on, but there was no output on the monitor at all, it didn't even get the monitor out of sleep mode.
After about 2 seconds I heard a 3 beep code, 1 long and 2 short. So I knew right away there was a defective part, but I had no way of knowing what it was (unless someone out there is a master of beep codes and has them all memorized).
Anyway I went about emailing different tech supports and following all their advice, here's a rundown of everything I've tried:
- put the motherboard in the cardboard box it came in, hooked up power, cpu, vid card, ram and powered up to test for a short: same result
- removed all extra drives (floppy, harddrive, optical drives) and powered up, same result
- removed the video card and powered up with just the cpu and ram, same result
- removed everything, powered up with ONLY motherboard and power supply, (this was supposed to force some other kind of beep code, however the result was no beeps at all, I informed the mobo tech suport and they just said that's normal)
- swapped the ram around to every single different combination, same result
- removed onboard battery, changed the jumper for the cmos to reset it, replaced battery, same result
...god what else...well it doesn't really matter considering I've tried pretty much everything there possibly is to try and I ALWAYS get the 3 beeps. I have a new video card on the way since evga is sure that's the problem, but ASUS feels it could be the ram, so I sent out another email today to g.skill about if the timing on the ram chips are compatible with the bios, and if not how to hard code the timings to something that will work.
Since I have to wait on the video card to get to me I figured I'd tap into the wealth of knowledge here.
I would like to point out that I'm new to the area I live in and do not know anyone with whom I can swap parts with, so any advice about try someone else's (insert part here) just isn't gonna happen, sadly.
Here's my system:
Lian-li PC-60BPLUS W
ASUS M2N-SLI Deluxe 570
AMD AM2 3200+ CPU
G.Skill DDR2 PC6400 2x1GB RAM
eVGA GeForce 7900GT KO 256MB video card
Antec 500W Smartpower 2.0 PSU
WD 250GB SATA2 HDD
Samsung DVD burner
Samsung combo drive
Sony floppy drive
Here's my system:
AMD AM2 3200+ CPU
WD 250GB SATA2 HDD
Samsung DVD burner
Samsung combo drive
Sony floppy drive
