I just ordered the Thermaltake Tsunami and it looks like the panel for the motherboard at the back of the computer wont fit the P5W DH Deluxe motherboard which I am getting. Does the motherboard I am getting come with a different panel so it will fit on the case?
How to Answer Your Own Questions 101:
Now class, bring up a browser on your computer or just click on the link the OP posted, namely:
Now scroll down and find the following component in the mobo's parts list:
"I/O shield"
Next, cut and past the above phrase into the search window on Google.com. The second link found will take you to a site with a photo of an I/O shield. Look at that! Problem solved. It's not that I don't want to help (I just did) but your own link had the answer built in.
Every mobo I ever bought came with the IO panel but I think some open box items do not come with the IO sheild... Its not realy needed but ALOT of dust will get to your comp from there well a good vacumeing does wonders but be warned alot of people think vacumeing your comp could kill it !!! (Hasnt ever happened to me knock on wood)
