ATI has a problem in the latest Catalyst drivers. Read more
Adoption of light-emitting diodes (LEDs) in high brightness panel backlighting applications, such as notebooks and LCD TVs, has been delayed due to overheating issues, according to sources in the Taiwan LED industry. Read more
Heat-pipe cooling solutions will account for 50% of PC products based on Advanced Micro Devices (AMD) CPUs in the second half of this year, up from 10% in the first half, according to thermal solution providers Asia Vital Components (AVC). Read more
When it came to cooling systems, Thermaltake had quite a few interesting thing to show. Air cooling wise, the manufacturer promoted 14 cm fans with two new models: the V14 Pro and the BigTyp 14 (the latter had already been seen at the CES). The first model, very wide, uses 6 heat pipes to send heat on the two copper heat sinks that aren't that thick, but that are wide. In between is the fan that is placed vertically, a la Zalman CNPS. It'll easily evacuate the casing's hot air but will provide only a small air flow to the chipset and the processor's power supply stages. On the opposite, the BigTyp 14 and its six heat pipes in U will handle this well and should have better overall performances for the processor. Both air cooling systems should be available in a month. Read more
Where were we in 2008 and where are we heading in 2009? In his State of the Personal Computer address, Alan Dang shares his insights as a user of three different platforms: Mac, Windows, and Linux. Read more
Flash-based drives take the performance segment by storm, but the good old hard drive still provides the best bang for the buck as capacities reach 1.5 terabytes. We scanned all the available offerings and found the best drives for winter 2008. Read more
Atom is geared for low-cost, low-power netbooks and nettops, while the device is a poor choice for desktop PC applications. We show you why Core 2 is better, and give some guidance on how to pick the best power supply for your low-power application. Read more
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
| Bottom | |
| Author |
Thread : Heat problem on opty 165
