Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Advice on adding second power supply.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Advice on adding second power supply.
I have a shirty Dell 8100 that shipped with a proprietary 250W back in '01. Well I'm in the dark ages running a Radeon 8500LE and I'm seriously ready for a system upgrade. But that won't be for atleast 6 months so I want to atleast upgrade my graphics card until then. Problem is.. I can't swap out my PSU because the motherboard connector is proprietary. There's no way that my PSU would handle it.
I was thinking about the Radeon X850PRO AGP at ATI.com for $139.00 or possible an x1600. I don't want to spend over $150 as this is just to tide me over until I build my new system. As everyone knows right now is a bad time to build.
So the only solution I have is to add another PSU dedicated to the graphics card. I'm assuming that the molex connector on the newer cards does most of the powering.. correct? So if I stick another PSU in there it should power the card and leave my proprietary PSU for everything else?
Inside my case I have a 5.5' x 7.5' x 5.5' (LxWxH) area under the HDD cage that I could put it. Does anyone know a PSU that could fit in that space? It doesn't even need to be good or have a high wattage.. so long as one molex can power the graphics card. That's all it would be running. Otherwise it will have to sit outside the case and run in through a PCI slot. I'd like to avoid that if possible.
Oh.. I'm running 3 HDDs, two optical drives, 4 sticks of Rambus, couple fans, Radeon 8500LE, and a 1.3 P4 on the old PSU. So no room on it for a new card.
Sponsored Links
X850PRO is better than the X1600 series.
I would suggest a 6800 series, if you can find it.
you prolly wont find a PSU, you may have to use the 5.25" PSU's
Reply to pengwin
- 0 +
AGP style Graphics arnt that power hungry unless you go for 6800 Ultra that needs 2x molex to run....
just try to keep your old system kicking over untill you DO buy a new system....
If you end up having to buy a new PSU buy one with your new system in mind so you can use it on your next MB and CPU..... ie 24 pin etc etc.....
Reply to wun911
Surely they would be too power hungry for a 250W with all that other equipment. I'm gonna look and see if I can scavenge one from work and just run it outside the system. I also don't want to spend too much on this stuff. Just enough so I can play some newer games on medium settings if need be. The AGP card will become worthless to me when I upgrade to pci-e.
Reply to qwertycopter
Thank you! Unfortunately, I must be on a streak of bad luck, because I happen to have an 8100:
Quote :
Pentium 4 Dell Models that are not compatible with this power supply adapter: Dell Dimension 8100
- 0 +
Quote :
ouch.
Qwerty, just wait it out.wont be too long.
Reply to pengwin
You shouldn't be worried about total power draw, IE 5.5v and 3v, you should woory about 12V draw. What are the specs on the side of your PSU, and, what is the E numer..... there should be an underwriters number on that psu.... underneath the RU..... should look something like this.... E12345.....
how many amps on the 12V rail?
I think that PSU would run it...... that is a low power system you are running.... the 1.3 doesn't draw a whole lot.
Reply to weskurtz81
- 0 +
Quote :
THANK YOU weskurtz, you can help me pound that message into people. total wattage isn't nearly as important as how many amps that 12v rail can push. i've fried 500w power supplies before that had only 19 amps on the 12v, my current 500w ps has 31 amps on the 12v and the system is rock solid. those other ps's are now being used for spare wiring as needed...
Reply to valis
I will look up the E number and specs when I get home. One thing I noticed is that it said 250W max output. Well the cards I looked at recommend atleast a 300W to run.
When you say 12V rail, are you talking about the yellow wire on the molex connector that would be plugged into the video card? Or can I test any yellow wire? Also, to test current I need to have the PSU on with devices connected to create a load, correct?
I did find a couple older PSUs at work. I was surprised to find that the molex connectors were Red-Black-Black-Orange. There was an orange wire rather than a yellow. Is this still 12 V?
- 0 +
color prolly faded...my guess.
Reply to pengwin
All you really have to do in order to find what it is SUPPOSED to put out on the 12V rail is multiply the 12V rail aperage by 12..... IE.... 15A*12V=180W.....
Even though ATI suggests a 350W PSU, it doesn't mean you need to waste money and buy one..... all you need to make sure of is that your 12V rail is not exceeded. It will be fairly easy to tell, your computer will simply shut off IF your PSU does it's job when the power is exceeded. But you should not have any issues.... I would not waste any time or money on it..... but that's just me.... and my suggestion.....
Valis-people tend to suggest getting 700W-1Kw psu's on here and it doesn't really matter how many times I say it, those suggestions still pop up, very few people would need that amount of power. And as you just said, you have a single rail PSU with alot of wattage on that rail.... I probably would not buy a daul rail psu for the simple fact that one of the rails is supposed to be for the CPU only.... and then the other rail is for all other 12V. IE, if someone intended to SLI, alot of the dual rail psu's would push 2 x1900xt's..... but your PSU would do it like a champ with almost 400W's on that rail. However the 3-4 12v rail psu's look nice.... but at the same time, most of those are above 600W and 600W would probably be the max I would buy, and since I don't ever plan on running SLI again, and probably won't ever buy an X-Fire setup..... I should NEVER need that much power.
Thanks
wes
Reply to weskurtz81
Quote :
Dell used to use crappy psu's AND have then custom wired to prvent people from useing non-Dell parts. I don't know if that is the same thing today.
As the system you have ids 5 years old the best thing you could do...if your a gamer..is to build yourself a new system.
Optron 146 (2Ghz stock but runs over 3Ghz on stock volts with a real psu, like a P4 @ 4.38Ghz)....$200 w/3 year warrenty.
7900GT....will give move output than the human eye can really see,play everything for the rest of this decade or longer and under $299 (some are less than $260 and they ALL overclock about the same).
Go forth and build young man!
Z
Reply to ZOldDude
ZOldDude.. well thanks for the suggestion. I'm not sure you read everything though because I did say I'm building. But not until things settle down in the CPU market.. and I'm also waiting on problems to creep up with perpendicular recording technology so they can get ironed out. Anyway it might not be for like 6 months anyway, in my case. So I have a piece of shirt system now that I want to get some better gaming out of. Really, it can't handle any FPS game from the last two years. I tried Doom 3 on lowest settings possible, 640x480 and I couldn't even hit 8 fps.. it was bad.
You know, I could upgrade the 1.3 GHz to 2.0 for $30 on ebay. And spend $70 on a 9800pro. And "acquire" an extra PSU from work to run the card... but I'm not sure it'd be worth it. So I'll trudge along on this piece of t-shirt and be wowed by the massive upgrade down the road.
Well I understand that the amps are key, but I really don't want to find my card underpowered down the road even if it sounds good on the sticker. I think it's in that gray area where is may or may not work. The card will be useless to me in that case since I'm dropping AGP in my build.
Quote :
That's been my problem all along and has really limited my upgrade path. They made a power adapter but my model happens to be an exception and therefore, SOL. I do know of a company that sells 400W replacements for my model.. but they are asking over $100 which is a load of bullshirt if you ask me.
Ima go sit and fume while technology passes me by once again. :?
- 0 +
I have the same dilemma with my power supply. I'm running a Dell 8100 1.3GHz P4 with 1G RDRAMM. I just purchased a new video card (AGP mind you) knowing I would need a new power supply. I did NOT know Dell locked me into having to buy their (the company that supplies their PS's) power supply for $105.
Now, to me it looks like I only have to find a PS with a 24 pin connector or a 24 to 20 pin & 8 to 4 pin adapters for a ATX PS.
Does anyone know if the adapters would work if I got a standard ATX PS?
or
Will a ATX PS with 24 pin set-up work?
Sorry if there is an obvious answer, but this is my first real upgrade.
Reply to bdgiant
Here's the problem: your motherboard uses two proprietary power connectors (24 pin connector with only 23 wires; 16 pin connector with only 9 wires). I have not found an adapter on the market that converts a standard 24pin PSU power cable into Dell's proprietary design. Here are the specs of your power connectors:
http://docs.us.dell.com/support/ed [...] .htm#power
Do not plug a standard 24-pin PSU into your board. They are wired differently.
This is the only option I found for upgrading my Dell PSU through someone besides Dell:
http://www.pcpowercooling.com/prod [...] show=S41D1
But for 99 bucks.. well maybe you can check on eBay or something. Me? I'm just gonna upgrade the entire shabang in a little while. Trust me, even with that new graphics card your 8100 is gonna be bleedin to keep up in the next year or so.
- 0 +
Thanks for the reply. But that brings up another question:
Does anyone know where I can find Michael Dell so I can kick him in the nuts? Thanks!
Reply to bdgiant
Sounds like you have decided against the add-on power supply, but I'll just add one more caution for that plan: you would need to be sure that the ground on the original PS output was at the same potential as the ground on the new PS output. Otherwise, current could flow between your video card and MB on "ground" lines in what is called a "ground loop".
Reply to Mondoman
- 0 +
Sooo, here is where I stand. To upgrade my computer to a tollerable system I would have to purchase:
$100 410W power supply
$80-$100 P4 2.8GHz CPU (the fastest my motherboard can handle)
$60 adapter because my motherboard sucks
$10 shipping
$250-$270 for a system that will be useless in a year or two.
BTW, The case for the Dimension 8100 is built ONLY for its motherboard, so a different MB is out of the question without a new case. And, I am not that handy re-wiring and soldering adapters for PS's so this is what I'm going to do:
$65 new MB - it's a dual AGP & PCI Express x16 so can keep my VC
$85 Athlon 64
$100 1GB ram
buy my friends year-old 480W PS and case for some beer ($7-$10)
Sell my old computer components to make up some of the money ($200)
In the end, I would only be paying around $65 for a better computer that will abe fully upgradble.
In short, sell out the 8100, kick Michael Dell in the nuts, and buy a new system (buy not a Mac)
Reply to bdgiant
Quote :
Interesting. Just what exactly would this ground loop do to my system? If both PSUs were plugged into the same power strip, would this guarantee they were at the same potential?
- 0 +
I don't know anything about ground loops, but I have read a few articles and other testimonials about people frying either the MB, PS, or both. It's not worth the risk to fry a marginal system and lose $100 in the process.
Reply to bdgiant
Take into consideration that if attempting to make you computer upgradeable, the only components that are decreasing in power demands are the CPUs.
Newer technologies are demanding more wattage and, also, more amps for the draw, which alot of people tend to overlook just because they favor a certain brand of PSU. The newer GPUs, if you plan to consider them for the future are going to be extremely demanding. The G80 is reported to demand 175 watts and the R600 200 Watts. That being said, just to be safe, anything less than 17amps per rail over a multiple rail system and you will be having to look for another PSU
Reply to phreejak
Quote :
What cards are these? Wait, the cards I'm looking at demand atleast 350 Watt PSUs. I'm confused...
I hadn't know whether this PSU you were looking for was to last for future upgrades or not and I was meerly cautioning you. Just trying to be helpful
Reply to phreejak
Forget the X850Pro; it will be totally bottlenecked by your P4 1.3. The highest card you should be looking at is a 9600Pro. You might even be able to run it without upgrading your PSU; just take out a hard drive or two :lol:
Reply to angry_ducky
- 0 +
Quote :
You might be standing in a very long line.
Reply to Sailer
Quote :
Ah fux! :( What if I upgrade to a 2.0 Ghz P4 (the highest this board can support)?
Ima turn it into a media machine and hook it up to my TV. Plop in a wireless NIC and an old Asus tuner card (meh!). After I build my Conroe or X2 system, that is. :twisted:
There are 1240 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
