speed of internet connection for VoIP
Last response: in Networking
Archived from groups: comp.dcom.voice-over-ip (More info?)
my internet connection isn't always the best, but I'd like to do VoIP.
Is there a test to see if the connection is fast enough?
[thufir@arrakis ~]$ ping www.google.com
PING www.l.google.com (66.102.7.147) 56(84) bytes of data.
64 bytes from 66.102.7.147: icmp_seq=0 ttl=244 time=60.0 ms
64 bytes from 66.102.7.147: icmp_seq=1 ttl=244 time=58.0 ms
64 bytes from 66.102.7.147: icmp_seq=2 ttl=244 time=91.2 ms
64 bytes from 66.102.7.147: icmp_seq=3 ttl=244 time=60.3 ms
64 bytes from 66.102.7.147: icmp_seq=4 ttl=244 time=59.7 ms
64 bytes from 66.102.7.147: icmp_seq=5 ttl=244 time=91.3 ms
--- www.l.google.com ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5004ms
rtt min/avg/max/mdev = 58.028/70.143/91.371/14.996 ms, pipe 2
[thufir@arrakis ~]$
this was ok, but sometimes I get 25% packet loss, or higher.
thanks,
Thufir
The variance (58-90ms) is not great.
Neither is that.
I have 300ms ping times to my VoIP server but there is no packet loss and
the ping times are extremely stable. VoIP works great for me.
miguel
Hit The Road! Photos from 36 countries on 5 continents: http://travel.u.nu
Latest photos: Queens Day in Amsterdam; the Grand Canyon; Amman, Jordan
<hawat.thufir@gmail.com> wrote in message
news:1121294362.937972.282790@z14g2000cwz.googlegroups.com...
www.adslguide.org.uk and select Speed Test. You will need Java enabled.
Requirements for a call using G711 is approx 80k in both directions.
Ivor
Related ressources
What's wrong with the variance? Does that mean that packet1 might
arrive after packet2, something like that? I suppose that happens no
matter what, so maybe if the variance is too over too great a range
then...?
> Neither is that.
I did some of those java tests, and I think VoIP will work in my case,
at least sometimes. There may be times when it won't work, but that's
ok for me.
-Thufir
> Basically if you have DSL or Cable, you are fast enough.
> Reliability is another issue.
This connection is wi-fi. The router, an SMC7004VWBR has a broadband
(cable) connection. This computer uses an asus wl-330g to connect to
the router. The VoIP would be routed through this computer. (Or, the
wl-330g might plug directly into a hub, and the VoIP adapter to the
hub, I'm not sure yet.) It's hard to pinpoint the problem areas with
regards to reliability and performance. It might be the cable network,
it might be the wireless connection, it's hard to say. It doesn't have
to be super reliable, I don't like phones anyhow ;)
-Thufir
Dear Friend,
Most of VoIP Service providers require fast Internet access.
But with Ubifone ( http://www.uninumber.ubifone.com/ ) you can start at
dialup speed, meaning from 56 KB.
Kind Regards,
Sam.
> [thufir@arrakis ~]$
> thanks,
> Thufir
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.voice-over-ip - 4876 messages and counting!
Ask the community
