Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > 3 problems someone please help
Forum Homebuilt Systems : General Homebuilt - 3 problems someone please help
i built my first comp the other day and loaded windows and well i have 3 problems.
1st. i can't get sound. it won't let me install the audio drivers for the mobo. something about hda or hdd(can't remember which one. at work now) missing cannot find. anyone know how to fix that.
2nd. it won't let me install usb 2.0 drivers. saying windows xp supports it but when i plug usb in it says it's not in highspeed port.
3rd. i had bought a 250gb hd. for some reason it's only saying i have 127gb.
Sponsored Links
Quote :
When you post questions PLEASE POST YOUR SYSTEM SPECS!! Otherwise it makes it really hard to help you. However, 2 of your questions are rather easy.
1) Need more info
2) Install SP2
3) Install SP2
Reply to shadowduck
Devils in the details. What motherboard? Windows XP I assume. BIOS version plz. Processer? RAM and video? Anthing in the PCI slots?
Reply to Darkchyld
sorry guys heres the specs
asus m2n sli deluxe mobo
amd athlon64 3500+ AM2
seagate 250gb
2x512 ddr2 533
bfg 7600gt oc
windows xp pro upgrade from 2000 nt
Reply to rider86
Quote :
seagate 250gb
2x512 ddr2 533
bfg 7600gt oc
- Yeah thats problems 2 and 3 right there. 2000 does not support USB2 or drives larger than 127GB. Upgrade to XP Service Pack 2 and those problems will disappear. It might help with problem 1 too. Upgrade to SP2 and post back your results.
Reply to shadowduck
shadowduck would i be able to send you an email about something.
Reply to rider86
Quote :
Use PM or post here again.
Reply to shadowduck
Once you get things up and running consider this.
I've done it and it makes future installs a brezze! :)
Reply to Darkchyld
Quote :
seagate 250gb
2x512 ddr2 533
bfg 7600gt oc
Thank you very much. i went and bought a REAL version of windows with sp2 and it seemed like sp2 did the trick. everthing is running perfectly. now if i can just find a way to keep my mobo from going up to 70 C and processor to 60 C without opening the case and putting a big fan on it that would be perfect.
Reply to rider86
That will depend on your case, what type of hsf you have and the ambient air temperature.
Reply to waylander
There are 908 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
