G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
I am trying to set up a DC with a child domain in the forest. But as
you can see from the text below that is was I keep running into. But
the funny thing is though I am able to join the parent’s domail, so
shouldn’t I be able to join with dcpromo?
If someone could please help me out on this one that would be great.
If you are wondering what I am doing, I am trying to set up some labs
at home So I can finish up on my labs.
SO here it goes.
The domain name headquarters might be a NetBIOS domain name. If this
is the case, verify that the domain name is properly registered with
WINS.
If you are certain that the name is not a NetBIOS domain name, then
the following information can help you troubleshoot your DNS
configuration.
The following error occurred when DNS was queried for the service
location (SRV) resource record used to locate a domain controller for
domain headquarters:
The error was: "DNS name does not exist."
(error code 0x0000232B RCODE_NAME_ERROR)
The query was for the SRV record for _ldap._tcp.dc._msdcs.headquarters
Common causes of this error include the following:
- The DNS SRV records required to locate a domain controller for the
domain are not registered in DNS. These records are registered with a
DNS server automatically when a domain controller is added to a
domain. They are updated by the domain controller at set intervals.
This computer is configured to use DNS servers with following IP
addresses:
192.168.1.1
- One or more of the following zones do not include delegation to its
child zone:
headquarters
(the root zone)
For information about correcting this problem, click Help.
My router acts as the dhcp, so I have configured the perfered dns
settings to 192.168.1.100 and the secondary (ISP) 192.168.1.1
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Active-Directory-DNS-Problems-ftopict353089.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1115836
SO here it goes.
WINS.
configuration.
addresses:
192.168.1.1
child zone:
headquarters
(the root zone)
