I'm trying to find a case that will have room for at least 3 hard drives (preferably more), and decent cooling for my new conroe chip. I think I want to use this power supply:
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
Do you recommend using that one?
My main problem is that my computer can't be too tall. This is where I'm hoping you can help me. Can you help me pick a case that would fit the criteria above as well as:
Max Height: 19"
Max Depth: 21"
I would prefer no blowhole as this will most likely cause a larger amount of noise (I'm looking for quiet). Also, I would not like a case window but would be ok with it if there is nothing else available.
Thanks for your help!
I did some searching and found this case:
http://www.newegg.com/Product/Product.asp?Item=N82E16811112099
What do you think?
Max Height: 19"
Max Depth: 21"
What do you think?
