G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
I had two DCs, two sites. The upgrade from 2000 to 2003 on the romote
server resulted in a problem which required the DC be demoted. The problem
also required a dcpromo /forceremoval option.
After that I followed the KB artcle to perform a metadata cleanup and it ran
succesfully with a dialog box stating the cleanup of the DC was complete.
However, if I perform a "dsquery server" to display all DCs, this server
still is listed. Running a DCDIAG on the remaining DC has no errors, all
tests pass. If I run DCDIAG on the demoted server, that fails as expected,
as it is no longer a DC.
So why the conflict between these two apps? Why does dsquery still list the
demoted server as a DC. A third server, a member server, does not show up
with "dsquery server", which is correct.
Can I manually remove all references in AD to the demoted server after I
power off?
dave Admin
power off?
dave Admin
