I need help badly must have installed XP + fully updating about a dozen times...
Old drive: 20Gb seagate ata slave(same cable as DVD/CD ide master
New drive: 250Gb samsung sata spinpoint(sata 1)master
When my system was built i connected my old hard drive to bring my old files onto my new hard drive, however when i try to:
remove the old drive(disabling in hardware device menu and then unplugging)..
.for some reason the old drive dosent show up using the 'safely remove hardware' program even though its visible/usuable in' my computer'
ii can disable it in 'hardware device menu' and xp will still load as long as the old drive is first in the boot order and connected
or
change the boot priority so my new drive is first
then xp dosent load, either:
trys to boot from cd then asks for system disk
or
ntldr file is missing
or
hal file is missing
if i put the old drive to the top of the boot order and attach the old drive then xp loads
I tried to use 'Partition manager' to install xp on my new system and also create copies of my xp partition, but it seemed to create lots of boot errors
(described above)and the reinstalling of windows ..aarrrrghhh
its as if the new drive needs the old drive before it can boot properly?????
__________
Ok it appears that the old drive has a boot.ini file, but not the new drive
here is what the boot file says:
[boot loader]
timeout=1
default=multi(0)disk(0)rdisk(1)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
I think partition manager somehow move the boot file to the wrong drive...so how do i get it back....if that is indeed the solution
or
or
or
hal file is missing
__________
[boot loader]
timeout=1
[operating systems]
