Archived from groups: alt.games.morrowind (More info?)
Hi!
I have a little problem with modifying my favorite mods, the Balmora
Underground Manor and Sakakis Manor:
I´d like to add teleport doors between the mods to get rid of the stupid
travel between the two places, because I like to use the underground
manor as a display and alchemy room for Sakakis Manor.
I simply added teleport trapdoors to the mods that lead into the
respectively other mod. While this works fine, two other teleport doors
from another interior cell in Sakakis manor have vanished so that I
effectively walk out of the cell into space.
Another door I have added earlier refuses to be deleted.
Anyone have clues on what to do?
I run all 3 expansions but modified the mods with only morrowind active.
CU
Michael
16.10.20und
Das Ministerium für Ruhe und Ordnung drückt sein Bedauern aus, daß
Mitarbeiter seines Dienstbereiches (ohne vorher Erkundigungen
einzuholen) den geplanten Erstdruck der neuen Regierungserklärung im
größten Abendblatt irrtümlich als böse Satire verstanden und demzufolge
aus der Zeitung entfernen ließen.
(Lutz Rathenow, Meldungen, 1981)
On Sun, 11 Jul 2004 11:45:42 +0200, Michael Wang
<bitte_replyto@verwenden.de> wrote:
> Hi!
Well, I have an idea. Try combining all mods needed for your modification.
To do this, start the Construction Set, load all needed mods and chose
"Combine loaded plugins" from the "File" menu. This will combine your
houses in a single mod. After that you only need to load this one mod
instead of two or more.
At least this will get rid of conflicts between differents mods.
