Well i just recently popped in my physix card(want to play some GRAW and SoF) and i put my temperature sensor on it, and about 1 1/2 hours into gameplay, the card gets hot and the sensor display is reading 52 celsisus. Now my sensor is off most of the time, by 5-8 degrees, so about 60 degrees celsius. Now im packing 2 7900GTXs, and a x-fi xtrememusic sound card, with the physix card at the bottom. It doesnt get too much airflow, so im curious of what i could fit on the bottom of my case to keep it cooler in the future. I put a box fan on my desk to relieve some stress of it, and the 7900GTXs, and its working for now.
My main question is, "What can i use to cool that physix card when i decide to pop it back in permantely?" I only have about 2 inches from the bottom of the case, to the card(from the fan to the bottom is about a inch-inch and half) Would a 80mm or a 120 fit down there? Theres no screwholes to hold the fan down, i may use tie wraps and tie them to holes that i might have to drill in the case. Im really out of options except for the drilling option. All advice and requests are of course accepted and appreciated. Thanks.
