Recently I have bought a set of computer for my friend. After I have installed Windows XP, the provided driver installed Most of them are OK.
But the main problem is that the Audio cannot play sound.
It says that it cannot find the PCI bus driver on the board. I have go to the ASUS Website and download the driver but the problem remains.
Can anyone help me?
If you have connected the front audio ports using the supplied front port cable, make sure the plug you used is the Hi definition plug and not the AC97 one. Iv'e had system delevered from out supplier with this done and it kills the Audio.
