Tom's Hardware > Forum > Storage > Hard Disks > Thick rubber bands for silent hard drive mount?
Forum Storage : Hard Disks - Thick rubber bands for silent hard drive mount?
I read about this in Maximum pc magazine, apperently you take 4 inch long by 1/2 inch rubber bands and suspend them in a 5 1/2 inch bay with a pencil holding the bands in place. You then take your hard drive and place it between the bands.
Has anyone ever tried this? Does it work well? Is there any danger involved that would outweigh any benefit?
Thanks,
Sponsored Links
I used this to mount a laptop hard drive to a desktop. In the article they used pencils to support the bands on the sides. Unfortunately when you do this, it is hard to put the drive cage back. I used the holes around the drive cage to mount the drive.
In my experience, once you install the drive, it seems rather stable, but not as stable as a standard installation. I don't think it should be an issue as long as you don't move the computer around alot and use good quality rubber bands.
Concerning the sound, I did not get a chance to hear the difference since the laptop drive is already pretty quiet in comparison to the rest of the computer. The reason I used the bands in the first place so to avoid buying an adaptor kit.
Reply to DrBlofeld
Sounds like an absolutely daft idea to me.
The rubber will dry out and stiffen within weeks in the heat inside the computer.
Eventually you will hear a loud thump, and if you're out of luck loose the drive or some of its data.
Reply to asdasd123123
I purchased a Antec case called the P150 that has installed rubberbands to do just what you are talking about. they were installed in the 3.5 bay area. I let you put it in the bands or use the screwless mount. I figured since I have a high power harddrive I should use the bands.
They were nice, they cut the noise down and I enjoyed them very much until they started to crack and finally broke after 2 months of use. I'm very happy it didnt bust up my HDD to bad.
Reply to clarkbark
so what if you double up the bands? Make them double thick then maybe keep an eye on them, you know set your calender to check them once in awhile? It sounds like it would cut down the sound a lot, I know my hard drive sends sounds/vibrations all through my case, especially if you put your hand on the case. You can feel the heads moving nicely, even when its mounted in a 51/2 inch bay with a mount that says its supposed to reduce noise/vibration. Rather then buy another product that lies about its features, I would like to have a fairly cheap solution that doesn't require a trip to the store for a return.
Also just to eliminate the idea that your hard drive will destroy itself if it falls, what about putting some kind of safety net below it? YOu know extra bands just under neath if it falls, it will only drop mayb a half inch or so.
thanks for the advice so far I never thought of the bands drying out.
Reply to cranbers
Quote :
As long as they are high quality thick rubber bands they will last a while.
But a better idea I think would be to get a few of the real small bungie straps. Take the hooks off and run them through the openings in you drive cage and tie knots in the ends to keep em there. May not work in all cages and I haven't tried it myself but it should work quite well. Basicly the same system Antec uses in the p150.
Reply to Jinx13
Quote :
But a better idea I think would be to get a few of the real small bungie straps. Take the hooks off and run them through the openings in you drive cage and tie knots in the ends to keep em there. May not work in all cages and I haven't tried it myself but it should work quite well. Basicly the same system Antec uses in the p180.
wow, thats a great idea and that will most certainly solve the problem of drying out rubber.
I will check walmart and hard ware stores for bungies that might accomplish that.
Reply to cranbers
Glad i could be of help, just make sure you tie the knots tight enough they don't give, and checking them on a semi-regular basis wouldn't be a bad idea.
Reply to Jinx13
Well, there's always teflon foam you can use.. That's heat resistant..
Quote :
Just a little warning. Hard mounting a HDD to a chassis (case) reduces HDD vibration by constraining the HDDs motion. Isolation mounting, acomplished by inserting some elastomeric medium (neoprene washers, "rubber bands", "bungy cords", silicon pads etc) actually allows the HDD to move more . Unconstrained motion in a HDD can lead to premature failure due to increased wear, resonance fatigue etc.
Im not trying to disuade you, just to let you know this can reduce your HDDs life expectancy so you dont wake up to a suprise some day.
Reply to turpit
Oh, I didn't know that. How did you find that out? That sounds very interesting, I wonder how bad the motion really would be, would it be worth having a quieter drive/computer? The drive does have a 5 year warranty so I guess that isn't a problem, it would suck however if my drive went out because of it all of a sudden.
How much quicker do you think the drive will go out?
Why didn't maximum pc magazine or the people at antec who do this/offer how to do it. IF it's dangerous to the hard drive? Wish they would of warned of it, guess I should write them a email huh?
Thanks,
Reply to cranbers
there is also the solution of putting a slice of rubber between the drive and the case, and using a screw with a spring: it reduces drive movement when you tighten the screws, but also absorbs some of the vibrations.
It's true letting a drive vibrate too much would be detrimental; if you suspend it using rubber bands, it will also increase said movement (due to swinging) and reduce its life expectancy.
Reply to mitch074
Quote :
word
Reply to Anonymous
Quote :
Thanks,
Well, as to how I found that out, my degree is in mechanical engineering, with some extra electives in vibration analysis. I’ve worked in an organization for the past 15 years which uses computerized equipment that is highly vibration prone and has to deal with that. And, I’ve been working the past 9 months on a personal project, part of which includes soft mounting multiple 3.5"HDDs to minimize vibration transmission. I’ve studied a bunch of commercially available stuff; including the “rubber blocks” you mentioned as well as some of the “rubber band” style mounts. None met the requirements of the project, so I was forced to design my own.
As for why maximum PC magazine and Antec didn’t consider vibration, I can’t say for sure. I can only guess:
1) It takes a lot less expertise to design a standard consumer PC case than it takes to design a HDD itself. In short, they simply may not have considered it.
2) Vibration in commercial static enclosures and chassis’s has only come into consideration over the past few years, and has been primarily aimed at noise reduction. Little attention has been given to the consequences, in other words, they probably have no experience with the problem.
3) PC HDD isolation products haven’t been out long enough for significant numbers of HDD failures to occur and give accurate data sets yet.
Vibration design concerns for military and mobile applications i.e. shipboard/aircraft/automotive/railway etc computer systems, have been around a very long time. Here the consequences of unconstrained vibration are much better known. Unfortunately, designing effective vibration isolation systems is a much more complex task and drives the enclosure/chassis cost up significantly. To apply that technology to a PC case could effectively double its size and quadruple its price.
Additionally, in a lot of mobile installations, HDDs as we know them are not used, and so those systems are not subject to the same considerations. It depends on the application. In some cases, permanent fixed memory is used, (ROM) while others use EPROM. Some others in aircraft and combat vehicles for instance, use a form of a RAM based system where the operating system and all data is loaded into volatile memory (RAM) prior to flight/operation, so there is no need to power up or access permanent memory HDD/FDD during operation. Once the system is turned of, all data is lost, and the system must be reloaded prior to its next use.
As for how much the HDDs life expectancy might be reduced, I’m sorry, but I can’t tell you what to expect. All I can say is the "softer" or more flexible the method you use the greater the reduction in life expectancy will be
Is it worth it? Personally, I think it is, but I am also willing to compromise. The rubber block system you used was fairly rigid. The rubber band method is fairly flexible. Opposites. Personally, I would look for a solution somewhere in the middle. Neoprene or soft silicone mounts. But those can be very expensive. Additionally, some of the stuff I’ve seen advertised (especially in silicone) is total crap.
If you have a 5 year warranty, I wouldn’t worry about it to much... If the drive craps out early, you’re covered. But I would definitely, definitely back up the critical data every once in awhile.
Reply to turpit
I was under the same dilema a few months back. Walking aroound Home Depot, I can across very thin Bungee cords. Used them, and they have worked perfectly for the last 4 months.
Reply to babybudha
Quote :
Thanks,
Wow, I don't mean to be corny, but it is truly an honor to have you a true expert and professional replying to my post on the subject.
I would say if you do find the perfect solution to your studies/experiments to apply for a patent and submit it to some major case vendors/designers for some quick cash, I know a lot of people would love having the perfect solution to this problem/issue.
As for what I'm going to do, I'm not sure a lot to think about, it's been overwhelming the amount of replies and ideas to my inquiry. I may try the rubber band approach for a moment just to see the difference. the reason why I want to silence my drive is well my drive i s a 7200.8 seagate and its quite loud when reading and writing. My case amplifies this quite nicely and I was hoping isolating the drive from the case would help a lot. But so far it hasn't really. This right now is what im using:
http://www.newegg.com/Product/Prod [...] 6817991002 and it doesn't work very well ive been having al ot of difficulting finding out how to mount it correctly as it doesn't have instructions.
Thanks again, Chad
Reply to cranbers
Quote :
Thanks again, Chad
Oh, I’m no expert, not by any means. Vibration analysis is a field unto itself. I’ve just had to deal with it peripherally on and off over the years.
Sadly, the HHD mount design I arrived at is an integral part of the overall project and not easily (or cheaply) adaptable to the commercial PC environment.
I looked at the mounts you’ve linked to when I was trying to find a ready made solution for the project, but they didn’t meet the requirements for size. Those were for a 5.25 bay.
Give the "rubber band" method a try. Use the bungee cords. As pointed out by another poster, the rubber bands will dry out. You can "adjust” the rigidity of the mount by adding or removing cord, and varying their tension. Personally, I would keep them fairly stiff.
There are also 1 or 2 commercially available versions of this mounting method that I’ve seen. Here’s a review of one example:
http://www.pcstats.com/articleview.cfm?articleID=1034
Just make sure you keep your critical data backed up.
Oh, one other thing to consider. If your drive seems excessively noisy, it may be ready to die. If its new, but seems too loud, you may want to exchange it.
Reply to turpit
I personally haven't noticed a problem with hard drive noise. I have a Raptor and a pair of Western Digital 250GBs and I think they're all really quiet - and the Raptor is always going, so I notice it but it doesn't bother me. Although, there are a few products that might help, and they're just a few bucks each...
Insulation Strips
These are the rubber strips mentioned, where you sandwich them between the drive and the rack, then screw the drives in. They can also be used on optical and floppy drives, by the way.
3.5" - 5.25" converters
These beasts turn your hard drive into a 5.25" drive - attach the adapters onto the sides of the drive, leave the bay cover in the case and screw the drive in like it was an optical drive.
Padded rooms FTW!
This is like wallpaper made to insulate noise. You just measure how much you need, cut it to fit the walls of your case, take off the backing, and stick it to the inside. Also cover your drive cages with it, to deaden vibration in important parts of your case.
Reply to yourmothersanastronaut
Wow! ok the subject, should I use the rubber bands has been answered! I used four rubber bands, to mount my hard drive, I cannot hear the hard drive, anymore!!!
before I used to hear a very loud access noise, as seagate drives are known four, at least the one I own.
My case is completely dead with no vibration. In other word when I would set my hand on my case, you cold feel a constant spinning vibration and every time the heads would move on the platter you could feel that on the case shell. Well now there is nothing! The hard drive noise is complete gone!
Amazing, and not to mention, the hard drive was a major push to get it in there, and it doesn't move now with even a good deal of force, so it's in there good.
If anyone is curious on what I did, I went to staples and bought a bag of rubber bands, #64 3 1/2 inches by 1/2 inch. A bag was only a 1.50.
I placed four of them total, two in the front area and two together in the rear. It was quite an effort to get the bands to stretch across the 5 1/2 inch bay, I then secured the bands with a piece of round metal on each side.
I am just amazed, also when you feel the hard drive it doesn't feel like its shaking too much.
Reply to cranbers
Quote :
It's more like 4 to 5 years. Not weeks. That's why I said use good quality rubber bands.
Reply to DrBlofeld
true - good quality rubber bands using natural latex (same as what is used in tires, but it doesn't have to be black) is very heat resistant - you can recognise them as they don't have a grainy but thready, irregular surface.
Reply to mitch074
Just use rubber grommets between the case and the HDD
Reply to phreejak
Quote :
Thanks again, Chad
I must say I am impressed with your level of knowledge on the subject, but I have some other points to note as well:
Good quality rubber may indeed be better against heat and drying, but I would think maybe the insulating washers used on faucets might also work. Unless these are some rubber/silicon compound, I don't know.
I would also think silicon might be better than rubber, since it doesn't have the tendency to dry and harden over time like rubber does. It wouldn't be difficult to make some silicon washers or spreading a thin layer of the stuff on whatever you have.
Laptops: they too use vibration isolation to protect HDDs, wouldn't this create the same danger issues you speak of? I actually remember seeing a fujitsu laptop that used sorbethane material to insulate the HDD. Would sorbethane work as suitable alternative to rubber bands?
Great posts everybody!
Reply to Luscious
Rubber Grommets sound like the best route to go. Wouldn't kill off the noise entirely, but would surely help :)
Reply to Darkfire001
Go to a hardware store. Buy some rubber gromets with a center hole just large enough for the hdd screw to pass through. Drill out the attachment holes large enough to put the gromet in if required. That will isolate the drive and attachment screws from the case and it will never fall. Rubber bands and pencils sound too much like bubble gum and bailing wire to me. Too many possibilities of failure unless you don't care about your data.
Reply to 4Aces
Bubble wrap? I can't tell are you being sarcastic? or are you saying better wrap it in bubble wrap because its going to fall?
Reply to cranbers
Sarcasm.
[sarcrasm]Hard to convey it with text, I'll try harder next time.[/sarcasm]
There are 915 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
