1. Updated the bios on the mobo to the current 2.20
2. Used Seagates Diskwizard to load their stuff on and then run the OS setup - this resulted in XP not seeing my harddrive.
3. Had to write ZEROs to the entire drive to get it back
4. installed xp pro with sp1 and then sp2 - still only 127gb
5. installed "reg_48bit_lba.exe" - this did nothing - still only 127gb
6. I tried putting the sata files on a floppy and installing xp and then hitting F6 and installing them - this did nothing.
7. Tried the SATA2 and SATA1 slots.
8. I am now writing ZEROs to the drive ONCE AGAIN
I can not find any other helpful topics on seagate.com or asrock.com or through MS. If anyone knows what I can do other than the above please help me out as I am out of options at this point, thanks in advance. FISH
That is a know problem in XP. If you don´t have atleast Service Pack 1 when you install the harddrive, then it will only be 127Gb...
Download Service Pack 2 for XP if you haven´t already done that.
If you format a 129Gb+ partition in NTFS using any software you can find, you can force even Win2K into recognizing a 200 GB+ drive - I did.
LBA is enabled in BIOS - otherwise WinXP would be unable to detect it (stupid OS). However drives of more than 128 Gb need 'Large LBA' support from WinXP - which was enabled by default only in SP2 for the Pro version.
If you don't mind partitioning your drive, you can:
- install XP on a 20 Gb partition
- install the registry fix needed to enable large LBA in XP
- create and format a 300 Gb partition
...or use a Linux liveCD to do as I said in my previous post. Yes, it works with a mouse. No, you don't need to enter complicated keyboard codes to run a live distribution like Knoppix. Yes, you'll get a full-fledged GUI. Yes, its partition manager is almost as powerful as PartitionMagic (called Qtparted). No, it costs nothing more than a blank CD.
Maybe try this. Right click on the 'my computer' icon, then select manage, then click on 'disk management'. It will show you all storage devices registered on your system. I use winXP home and had to manually activate my harddisk this way for windows to see it. You might also have partitioned the drive and you need to activate the other half through this method.
i dind't know if you done this but after you install SP2 you have to go to the disk management in the admi tools to activate the rest of the hard drive and then format it, if you've done that , that's a weird problem.
Have you tried partition magic once windows is installed? It may allow you to "stretch" the primary partition to use the full drive.
I have done this before but a couple of years ago and it did work.
Didn't need to do it on my current install. which is similar to yours: AMD64 3500+ and 939DualSATA2 mobo. As far as I can see, it must surely be a BIOS setting somewhere. What mode are you running the drive in SATAII or IDE mode? (not sure it will make a difference but worth a try).
there ya go thats about the easiest thing so far, that and the lenux idea. Just incase you missed how to partition and format a hdd the right way in xp this is how its done step by step.
Start>Control Panel
Adminstrative Tools
click on the Computer management shortcut
this brings up a computer mangement program, look near the bottom for the + sign by the Storage, if its not open, open it.
Higlight the Disk Management this should show you hdd as 127gb partition then about 200gb as unpartitoned unused space.
you then right click on the unpartioned space in the little graphical representation of your hdd and click make partion (not so sure on what exactly it says in the menu options but you shuld get the jist of what im saying when you do this your self)
once you make the partition you right click and say format, then bingo you have your full hdd space.
If you want one full 320gb hdd not two partitions use a friends pc to do this but you will need to delete the 127gb partion you have then make one big one.
your only other option is to slipstream sp2 with your xp disk Im not going to go over that just google "slipstream xp" and you should find instructions on how to do that.
not sure. slipstreaming SP2 doesn't always modify the installer's registry (the installer hasn't changed since original XP, and is a small NT kernel with a text GUI). You need to modify its registry too.
Try XPlite to slipstream it, and add the Large LBA compatibility check. That would work.
OK im guessing you installed XP (NO SERVICE PACK) 1st when you reinstalled, well then guess what even though you updated the other space is an unused partion however you can create another partion and use the space. Basicly you will have 2 hdds... :\ happend to me 2
How you do it
(note my control pannel is set to old school Windows version..type)
Go to Control Panel
Administration Tools
Computer Managment
on the left panel thingy click on Disk Management
There you should see your HDD saying Unused Partion Space or somethign to that effect then you click on it and Create Partition or something to that nature
