G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
I’ve been searching for a few days now and have found many articals
about running adprep.exe and making sure that you run a script called
InetOrgPersonPrevent.ldf to prevent “mangled” records if you have
Exchange 2000 sp2 or below in order to prevent the "mangled" record
problem. But this is the problem that I’m seeing.
I’m running 5 DCs total...two on my current site and one on each of my
remote sites connected via T1s. I have one domain in the forest. I
need to prepare AD for a Window Server 2003 upgrade from Window 2000
Advanced Server sp4. I’m running Exchange 2000 Sp3, and found out
that I don’t need to run the script to prevent "mangled" records. So
I logged into my DC that is the Schema Master and tried to run adprep
/forestprep from the Windows Server 2003 cd. (Note, my Schema Master
and Infrastructure Master are on the same DC so I would rung adprep
/domainprep afterwards). I get the following error message:
“Adprep was unable to extend the schema.
[Status/Consequence]
There is a schema conflict with Exchange 2000. The schema is not
upgraded.
[User Action]
The schema conflict must be resolved before running adprep. Resolve
the schema c
onflict, allow the change to replicate between all replication
partners, and the
n run Adprep. For information on resolving the conflict, see Microsoft
Knowledge
Base article Q325379.”
But when I looked at this article it referred me to the scripted I
mentioned above and the error I get when I run it is:
Connecting to "DODC1.mydomain.com"
Logging in as current user using SSPI
Importing directory from file "inetorgpersonprevent.ldf"
Error occured during initialization
File operation failure
0 entries modified successfully.
An error has occurred in the program
So, I thought I should run dcdiag.exe on that DC and see what I
get….this is the output:
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: intown\DODC1
Starting test: Connectivity
......................... DODC1 passed test Connectivity
Doing primary tests
Starting test: Replications
......................... DODC1 passed test Replications
Starting test: NCSecDesc
......................... DODC1 passed test NCSecDesc
Starting test: NetLogons
......................... DODC1 passed test NetLogons
Starting test: Advertising
......................... DODC1 passed test Advertising
Starting test: KnowsOfRoleHolders
Warning: CN="NTDS Settings
DEL:089a4f2e-cc3b-4064-83b2-cc2a9208c56c",CN=DODC1,CN=Servers,CN=into
wn,CN=Sites
,CN=Configuration,DC=<edit>,DC=<edit>,,DC=<edit>,,DC=<edit> is the
Domain Owner, but is deleted.
......................... DODC1 failed test
KnowsOfRoleHolders
Starting test: RidManager
......................... DODC1 passed test RidManager
Starting test: MachineAccount
......................... DODC1 passed test MachineAccount
Starting test: Services
......................... DODC1 passed test Services
Starting test: ObjectsReplicated
......................... DODC1 passed test ObjectsReplicated
Starting test: frssysvol
......................... DODC1 passed test frssysvol
Starting test: frsevent
......................... DODC1 passed test frsevent
Starting test: kccevent
......................... DODC1 passed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x0000165B
Time Generated: 06/02/2005 16:08:35
Event String: The session setup from the computer SPEDNC-3
An Error Event occured. EventID: 0x0000169E
Time Generated: 06/02/2005 16:15:54
Event String: No suitable Domain Controller is available
for
Time Generated: 06/02/2005 16:21:48
Event String: The session setup from the computer SPEDNC-1
......................... DODC1 failed test systemlog
Starting test: VerifyReferences
......................... DODC1 passed test VerifyReferences
Running partition tests on : Schema
Starting test: CrossRefValidation
......................... Schema passed test
CrossRefValidation
Starting test: CheckSDRefDom
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test
CrossRefValidation
CheckSDRefDom
Running partition tests on : <edit>
......................... <edit> passed test
CrossRefValidation
......................... <edit> passed test CheckSDRefDom
Running enterprise tests on : alexandria.k12.mn.us
Starting test: Intersite
......................... <edit> passed test Intersite
Starting test: FsmoCheck
......................... <edit> passed test FsmoCheck
I’m wondering if it has something to do with the Domain Owner and that
is was deleted….it had said this for the Schema Owner, but I found a
Microsoft article that told me how to fix this. I inherited this
from the previous Network Admin and am just finding a lot of this
stuff out that wasn’t done right before. Any help is
appreciated….thanks! J
Mathew
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Active-Directory-adprep.exe-problems-ftopict542149.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1708421
upgraded.
[User Action]
the schema c
partners, and the
Knowledge
Doing primary tests
wn,CN=Sites
KnowsOfRoleHolders
for
CrossRefValidation
CrossRefValidation
CheckSDRefDom
CrossRefValidation
Mathew
