Hi, I am going to buy my first computer which is mostly used for gaming. Please give me your opinion. Also, can anyone tell me if I need to get a cooling device for my CPU or any other parts ?
Thanks,
I've got to agree on the sound card. Onboard sound is pretty good these days. put that money toward gfx and get a sound card later if you feel you really want one. The performace hit for onboard sound is not nearly as big as having an inferior gfx card.
As far as cooling goes, use the one the processor comes with, unless you plan to OC.
If you planning on a high OC, watercooling is the way to go. A moderate OC will do fine on air and in that case I'd recommend a Zalman.
As far as your HDD, you may consider getting two smaller drives and running raid 0.
You won't see any massive increase in graphical performance with that switch, and it'll actually hurt in some games where it'll try to run the SM3.0 path, which is more complex, requires more power, etc.
The reason I chose that COOLER MASTER case is because I plan to move to another city in the end of this year and I think the case handle will be very helpful.
I dont intend to overclock my system (at least in the near future) so maybe I will go with the CPU cooler.
It is too bad that I have bought the sound card yesterday (as I found the deal on dealsea.com), but I will increase the budget for graphic card if it worths.
Definatly agree on nixing the sound card and upgrading the graphics. You'd be giving up to much video performance for very little audio. I'd also recomend scaling back the ram to 1 gig(2x512). Since this is you're first system I wouldn't dive in head first with the 2gigs seeing as you probably won't need it right away. When you do you'll be able to easily add it for a total cost that will probably be cheaper. The extra money can then go to a better graphics card. If already plan on spending $100 + $80(-sound) + $60(-1gig ram) that puts you at $240 plus maybe a little extra and you're in the market for a pretty sweet card.
