I have a Compaq SR1151NX with a PTGD1-LA motherboard.
I bought a new Pentium D 805 dual-core processor to upgrade my old processor that came with the computer. Also, to try to overclock it eventually...I am sure that will be a different post
I have updated my BIOS (AMI v3.28) to accept the newer dual-core processors, and everthing was working fine with the new BIOS and old processor.
I took the motherboard out of the case and fitted my new cpu and HSF. Put the MB back into the case and then it wouldn't even POST. No beeping...just the case fans and HSF powered on. The monitor read "NO SIGNAL". To test that it was a cpu problem I replaced my new cpu and put back in my old stock cpu w/HSF and turned on the computer. The HSF came on full force and the comp will eventually shut itself down, I assume because of the high temp of the cpu. It will boot to Windows (XP Home SP2) with the old cpu...but not for very long. My temps read 102degC 215degF.
Two part problem - Why didn't my new processor work and what is wrong with my old processor? Is this a MB issue?
