Yes this can be done. If you drill a hole, make sure it's the size of the inside diameter of the fan, and also drill 2 or 4 holes that line up with the fan screw holes. Either remove the MB, or fully cover any exposed components with a cloth/blanket or fashion a cover out of cardboard. So, if you are putting the hole on the case side cover, trace the outline of the fan to be used with a pencil..including screw holes. When you go to cut out the holes, put masking tape around the hole so as not to scratch the paint. Wear safety glasses,i'm sure you realize that Dremels spin very fast. GLNo, I mean right now the side of my computer is just a solid piece of aluminum. I want to chop through it with a dremel and stick a fan in the hole. Will this work? Or are they supposed to be mounted only to certain spots? If so and I have a standard aluminum case with no fan hole, the only fan is on the GPU and PSU, how could I add more fans?
I know nothing about cooling, so any help would be appreciated.
edit. I do have enough intelligence to know that if I do try this I should remove the MB to prevent filings from getting on it. I already dremeled an add-on PCI slot into the back of case to fit the fan for a x1900xtx.
Is it possible to add case fans to a case that isn't pre-made for them? What if I just cut out holes with my dremel tool?
Good suggestions with the exception of the duct tape. I have found that when i used duct tape(as usually happens with all tape over time) the edges eventually loosen and curl, causing all the dust,lint and hair to collect on the tape...making a mess. Wire ties work good though.the first thing on your to-do list should be to tidy up those cables... those cause a HUGE disruption in airflow. Ductape and sire ties can work wonders!! Also, use flat pata cables instead of rounded ones. flat pata's can be taped to the bottom of the case and wont disrupt airflow at all.
cooling is kina like the recent intel vs amd battle
intel tried to make things faster (adding more fans)
amd made things more efficient (clean up cables)
amd processors were way better
and if you want to get a conroe (leafblower) and put it in your case then go ahead.....
:lol:
