Cross-site browsing issue
Archived from groups: microsoft.public.win2000.active_directory (More info?)
We have an old two-site (US and UK) NT domain setup. The sites are
joined by a Lan-to-Lan VPN. There are two NT domains, each based
primarily in one site, but with a BDC in the "other" site.
Browsing works as expected, you can see all machines in each domain,
irrespective of site.
Now we merge with a Swedish company using AD and I decide to use
their AD for the whole organisation. I build a VPN to join the
Sweden Lan to the other two, and set up an AD DC in the UK. I set
up full two-way trust relationships. I move a couple of machines
in the UK into the AD domain. All works fine.
All except browsing that is. From a machine in the UK I can see
all machines in the old NT domains but in the AD domain I can only
see the machines in the UK, none of those in Sweden. The reverse
if I RDC to a machine in Sweden and browse from there. There
are no obvious errors in the Event Logs of any of the DCs.
Shouldn't cross-site browsing "just work"?
Jim Hatfield
12 answers Last reply
More about cross site browsing issue
  1. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    It's almost always a WINS Server issue:
    1) Lack of a WINS server
    2) All machines NEED to be "WINS clients"
    (this includes especially all servers, DCs and even the
    ` WINS server itself.)
    3) Failure to replicate the WINS database --
    with more than one WINS server they must be replicated
    The first is likely at the remote site (new Swedish company).
    The second is common when only a subset of servers are "missing";
    the latter is quite common when two companies are involved if
    each has it's own WINS server (set) and they have not been manually
    configured to replicate.
    Herb Martin, MCSE, MVP
    Accelerated MCSE
    http://www.LearnQuick.Com
    [phone number on web site]
    > Jim Hatfield
  2. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Thu, 7 Jul 2005 13:07:26 -0500, "Herb Martin" <news@LearnQuick.com>
    I thought WINS wasn't required with AD....
    However both DCs are WINS servers, both point their WINS client
    to themselves, and they are now configured to replicate. Sadly
    it makes not a blind bit of difference. The DCs (and a client
    machine) can browse everything in the old NT4 domains but only
    local machines in the AD domain.
    I see one difference. The AD domain name is "internal.local". On
    the new DC in the UK if I do a "net view /domain:internal", I see
    the list of local machines, same as if I just do a "net view". On
    the old DC in Sweden, doing a "net view /domain:internal" gets me
    an error 6118 "The list of servers for this workgroup is not
    currently available". So *something* is not right there...
    If only Windows browsing wasn't so obscure and difficult to debug...
    Jim Hatfield
  3. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    "Jim Hatfield" <jim.hatfield@insignia.com> wrote in message
    news:evp4d1hq6roh11dj00362lguoa6d026fjq@4ax.com...
    It's a VERY common misconception -- due to a LOT of bad information
    out there.
    If you needed WINS under NT-4 it is a VERY safe bet you need it under
    AD.
    All machines, not just clients OR DCs, have to be WINS clients for
    browsing to work fully.
    Check the WINS database (MMC) and use BrowStat.exe to troubleshoot
    that your browsers are available...
    It's actually fairly easy but TERRIBLY explained and poorly understood
    by most people.
    I only know about 5-10 rules but those solve almost every browsing
    problem.
    Also make sure you have a browsing problem which is almost entirely
    divorced from either of "connectivity" (ping by number) and some what
    separate from Name resolution "name to IP."
    Oddly enough, it requires WINS to browse across subnets and across
    domains, yet DNS may be the name resolution used to resolve the name
    to an IP.
    The reason: Master Browsers and the Domain Master Browser of each
    domain use WINS as a "locator service" or "rendezvous service."
    And remember ANY Windows machine MAY become Master Browser
    of it's subnet (depending on "rank".)
    Accelerated MCSE
  4. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Mon, 11 Jul 2005 13:41:32 +0100, Jim Hatfield
    The more I look, the more problems creep out of the woodwork.
    - if I run Domain Monitor on the NT4 PDCs, the status of the
    AD domain is listed as "domain controller not found". I have
    lmhosts entries to help netbios resolution but it doesn't
    seem to help.
    - the instructions for ADMT says to add each domain's Domain Admins
    global group to the other's Administrator's local group. However
    if I go into User Manager on the NT4 domains, open up Administrators
    and then select the AD domain from the dropdown, the list of
    names goes grey and is replaced by the message "Unable to browse
    the selected domain because the following error occurred: there
    are currently no logon servers available to service the logon
    request.
    - there are lots of errors from NETLOGON in the event log of the
    NT4 PDCs like: No Windows NT Domain Controller is available
    for domain INTERNAL. This event is expected and can be ignored
    when booting with the "No Net" hardware profile.
    - just doing a "net view" on the original AD DC now gets me an
    System Error 6881.
    jim
    Jim Hatfield
  5. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    > seem to help.
    The PDC Emulator must be online for cross-domain browsing to
    work. Only the Domain Master Browsers (PDC) exchange full
    domain lists .
    On the AD side, run DCDiag on every DC (good to do anyway.)
    Fix or report problems. (See below, I will add my DNS checklist
    but much of that is focused on straightening out DCs.)
    > request.
    External Trusts SEEM to be working but they are also depending on
    NetBIOS (and maybe WINS) so this is not too suprising.
    Consistent with not finding the PDC EMulator or maybe ANY DC,
    of the AD domain. This also seems to point at WINS.
    > System Error 6881.
    Accelerated MCSE
    news:lr55d1p2dv5nm0gim2a3lv2bg6b2410ilb@4ax.com...
    > jim
    > Jim Hatfield
  6. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Thu, 07 Jul 2005 18:45:39 +0100, Jim Hatfield
    I think I might have found something. In the WINS database I
    see the Domain Master Browser for the domain is set to
    192.168.0.210 - but that is not the address bound to the network
    card. It is a second address which seems to have something
    to do with RRAS.
    Is there a way I can force the Domain Master Browser entry to
    a particular address on a multi-homed machine?
    Jim Hatfield
  7. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Wed, 13 Jul 2005 13:32:26 +0100, Jim Hatfield
    >to do with RRAS.
    Further to this, if I reboot the machine, everything suddenly
    works fine. Both machines can browse all machines in both
    sites, and the "nbtstat -n" shows up no errors at all. Interestingly,
    "nbtstat -n" on the machine which has the RRAS server ONLY shows
    the Ethernet card address.
    Then as soon as someone makes a PPTP connection it all goes
    pear-shaped again. Cross-site browsing fails and nbtstat -n
    returns the name of the machine in the conflict state.
    So it is becoming increasingly likely that RRAS is the issue.
    Jim Hatfield
  8. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    I would carefully check the subnetting.
    It appeared you have two network interfaces, with NetBIOS enabled,
    on the same SUBNET (or broadcast domain.)
    I cannot be sure since you didn't show the subnet masks.
    You might post your IPConfig /all from the affected (DC) machine.
    Accelerated MCSE
    news:2dead15tdmbfc73ndgqejeupnb74colqh6@4ax.com...
    > >to do with RRAS.
    > Jim Hatfield
  9. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Wed, 13 Jul 2005 14:03:39 -0500, "Herb Martin" <news@LearnQuick.com>
    I believe not because the subnet mask of the RAS adaptor is
    255.255.255.255.
    Sure:
    >C:\Documents and Settings\Administrator>ipconfig /all
    >Windows 2000 IP Configuration
    > Host Name . . . . . . . . . . . . : server3
    > Primary DNS Suffix . . . . . . . : INTERNAL.local
    > Node Type . . . . . . . . . . . . : Hybrid
    > IP Routing Enabled. . . . . . . . : Yes
    > WINS Proxy Enabled. . . . . . . . : No
    > DNS Suffix Search List. . . . . . : INTERNAL.local
    >Ethernet adapter Local Area Connection:
    > Connection-specific DNS Suffix . :
    > Description . . . . . . . . . . . : Intel(R) PRO/100+ Server Adapter (PI
    >LA8470B)
    > Physical Address. . . . . . . . . : 00-02-B3-02-89-F7
    > DHCP Enabled. . . . . . . . . . . : No
    > IP Address. . . . . . . . . . . . : 192.168.0.101
    > Subnet Mask . . . . . . . . . . . : 255.255.255.0
    > Default Gateway . . . . . . . . . : 192.168.0.1
    > DNS Servers . . . . . . . . . . . : 192.168.0.101
    > 192.168.0.1
    > Primary WINS Server . . . . . . . : 192.168.0.101
    >PPP adapter RAS Server (Dial In) Interface:
    > Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
    > Physical Address. . . . . . . . . : 00-53-45-00-00-00
    > IP Address. . . . . . . . . . . . : 192.168.0.210
    > Subnet Mask . . . . . . . . . . . : 255.255.255.255
    > DNS Servers . . . . . . . . . . . : 127.0.0.1
    It's interesting that between the time the machine is rebooted
    and the time that someone makes an incoming PPTP connection,
    all is OK. As soon as the PPTP connection is made, the machine
    can no longer browse.
    Jim Hatfield
  10. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    news:qv6dd1dpd70hde7uj8ikd0e2jd4gskgkju@4ax.com...
    > 255.255.255.255.
    Alone that proves nothing -- it might even be wrong depending
    on where it appears.
    > Sure:
    Adapter (PI
    > >LA8470B)
    Right here may be part of the problem -- certainly if you
    have a routing issue.
    Why is the main NIC set to itself as a Default Gateway?
    Such settings will prevent the machine (and the routers
    on the machine in RRAS) from routing to any NIC (or
    RRAS interface) NOT directly connected.
    > > 192.168.0.1
    This looks wrong too, but I cannot remember if there is a cosmetic
    bug that shows this in dynamic interfaces.
    Were this really being used you could not reach any other stations
    on that interface. But I believe this is a cosmetic interface but that
    I have seen below.
    Why is there no DNS server set on the main NIC?
    And it really should be the IP since it will give this value to
    the RRAS clients (and 127.0.0.1 will NOT make sense for them
    -- that would refer to themselves.)
    Do you have WINS servers or not? If so, this machine should be
    a WINS client.
    What happens when you do "Net View /domain:DOMAIN_NAME"
    (before and after the connection.)
  11. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Thu, 14 Jul 2005 21:44:13 -0500, "Herb Martin" <news@LearnQuick.com>
    >Adapter (PI
    >> >LA8470B)
    It is not. The main NIC is 192.168.0.101 and the gateway
    is 192.168.0.1, a multihomed Linux box.
    This isn't the main NIC, it's something to do with RRAS.
    >a WINS client.
    The machine is itself a WINS server.
    After, ie now, I get a long pause then:
    >C:\Documents and Settings\Administrator>net view /domain:INTERNAL
    >System error 6118 has occurred.
    >The list of servers for this workgroup is not currently available
    To do the "before" I will have to wait for a quiet period when
    nobody is using the PPTP server, and reboot the machine. I'm
    slightly nervous about this because it's in Sweden and I'm not :-)
    Jim
    Jim Hatfield
  12. Archived from groups: microsoft.public.win2000.active_directory (More info?)
    On Sat, 16 Jul 2005 01:28:59 -0500, "Herb Martin" <news@LearnQuick.com>
    >Then it should be a WINS client (usually of itself.)
    Yep, it is a client of itself. Same with the new DC which I
    installed here in the UK.
    >Check any firewalls, including the SP2 type firewalls; this KB article
    >offers
    >specific ideas on this error (but it may not be your problem):
    I have set up the three LAN's with Lan-to-Lan VPN connections and have
    made sure that there are no packet filters blocking any inter-Lan
    traffic.
    I think this is the only realistic option. If it proves my
    suspicion that the RRAS service is causing the problem then I
    will just have to find another machine to run it on.
    I might play around with disabling the RRAS service for short
    periods when nobody is connected to see if that does anything.
    Jim
    Jim Hatfield
Domain LAN Active Directory Windows
