G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
Hello all,
I have a Wsf-Scriptfile that I would like to run on all our machines on
startup. Because it requires to be run with cscript.exe I have
configured a CMD file to be run as startup script.
It is configured as:
Script.exe //H:CScript //NoLogo //S
\\[domainname]\sysvol\[domainname]\scripts\serverstart.wsf
It looks like the wsf file is not run at all, however.
I also tried the following, but without success:
serverstart.wsf
In the GPO, the script is configured to be run as:
\\[domainname]\sysvol\[domainname]\scripts\serverstart.cmd
The Script and CMD works without problem if I run it manually after the
server is started and I log on to the machine.
Again I have tried without the path, but without success.
Is there anyone that has experienced and solved similar problems?
Thanks in advance for any help...
Markus
Hello all,
serverstart.wsf
Markus
