Your fine but if you do a seerious videocard upgrade (we are talking x1800 or x1900 here) you will probably need a bigger power supply.
But as a refrence i am running a 7800gt an AMD 3700 with 2 gigs of ram on an Asus A8N-e with a 480 watt antec.
No, not really that 450w is pretty much fine for any single gpu system... the only reason to upgrade the psu would be if he went SLI or CF or had like 6 raptors in raid0 and 10 fans and 4 cold cathodes and a water cooling rig which ran off the 12v line.
I'm also running a 3200+, DVD/RW, 1 SATA HDD and HiS X800GTO in an Antec Sonata II with the SP II 450W. Running a 15% OC on both CPU/GPU 24/7 - runs smooth as butter.
Plenty of power for that system. The 3800 X2 will use around 65W stock, and if you have a 1800XT it would be around 100W. So as long as you have a good 12V rail, or two, you would be just fine. I ran a 7800GTX SLI 165 OCed system on 480W Neo Power... never had any issues.
It will be good, most times systems don't got over 300 or 350 watts. One thing you may have just had a stupid on is you've got an am2 mobo and ddr2 memory but you said a socket 939 processor, you'll want to get the am2 version of the 3800+.
the NeoHE 430w delivers more 12v power than the 450w smartpower.
LOL good catch. I ment the Am2 X2 3800+. Thanks for pointing out my stupid mistakes.
Then I should have been more clear. I was giving two examples of relatively low-power PSUs that are easily powering high-end systems. At least low-power compared to the 600W+ PSUs that are currently on the street.
true. So, nice n' hot in in the middle east?
Actually, its not bad. I kno I came from the Middle East. Its a dry heat. better than the stupud humid heat in Illinois
It's baking over here - day and night. I come from hot/humid weather - right on the coast of the Gulf of Mexico - and this heat slaps me in the face! And the worst part is that the hottest month is right around the corner....
oh. I'd rather have Middle East heat than Humid heat. hate humidity.
I don't know what the big fuss is over huge power supplies these days, you guys got nothing on my 385W system, it runs like a charm. Just look at the specs below..
