Archived from groups: microsoft.public.win2000.active_directory (
More info?)
Hi Jorge,
Yes i removed manually now its disappeared from share.
Thanks
Shaik
"Jorge_de_Almeida_Pinto" wrote:
> "" wrote:
> > Hi,
> > I configuered DFS for my servers but after that i removed
> > the DFS but
> > while browsing the system the shares created by DFS still
> > showing,how its
> > happend and what i have to do for removing this.
> > Shaik
> Each root server has a share that is used for the namespace and
> beneath that share you will see folders representing the namespace. As
> you may have tried those folders are inaccessible.
> Each link is a UNC path to a server and a directory on that server.
> Again shares are used.
> If you don’t use a certain DFS replica for a certain DFS link than
> you can remove the share manually by right clicking the shared folder,
> selecting properties, selecting the sharing tab and selecting do not
> share the folder or remove share if more than 1 share exists for the
> folder
> The conditions and procedure applies for the root share
> Only remove things is you don’t use them!
> Posted using the
http://www.windowsforumz.com interface, at author's request
> Articles individually checked for conformance to usenet standards
> Topic URL:
http://www.windowsforumz.com/Active-Directory-DFS-problem-ftopict400997.html
> Visit Topic URL to contact author (reg. req'd). Report abuse:
http://www.windowsforumz.com/eform.php?p=1329804
