Archived from groups: microsoft.public.win2000.active_directory (
More info?)
"Ace Fekay [MVP]"
<PleaseSubstituteMyActualFirstName&LastNameHere@hotmail.com> wrote in
message news:ux7TAAFuFHA.1472@TK2MSFTNGP15.phx.gbl...
> In news:eg$xbq2tFHA.2624@TK2MSFTNGP12.phx.gbl,
> YMan <yyyy@yyyy.com> made this post, which I then commented about below:
>>> Thanks YMan. Looking forward to the config info.
>>> Ace
>> Hi Ace,
>> Sorry for the delay as I got hung up with something. Please note that
>> I chaged the domain name for security reason (hope you'll understand)
>> and others stay as they are.
>> First of all here is the ipconfig /all from a client computer
>> Windows IP Configuration
>> Host Name . . . . . . . . . . . . : MyXP
>> Primary Dns Suffix . . . . . . . : mydomain.com
>> Node Type . . . . . . . . . . . . : Unknown
>> IP Routing Enabled. . . . . . . . : No
>> WINS Proxy Enabled. . . . . . . . : No
>> DNS Suffix Search List. . . . . . : mydomain.com
>> Ethernet adapter Local Area Connection:
>> Connection-specific DNS Suffix . : mydomain.com
>> Description . . . . . . . . . . . : Intel(R) PRO/1000 MT
>> Network Connection
>> Physical Address. . . . . . . . . : 00-08-74-F1-D1-B1
>> Dhcp Enabled. . . . . . . . . . . : Yes
>> Autoconfiguration Enabled . . . . : Yes
>> IP Address. . . . . . . . . . . . : 192.168.88.241
>> Subnet Mask . . . . . . . . . . . : 255.255.255.0
>> Default Gateway . . . . . . . . . : 192.168.88.1
>> DHCP Server . . . . . . . . . . . : 192.168.88.10
>> DNS Servers . . . . . . . . . . . : 192.168.88.10
>> Lease Obtained. . . . . . . . . . : Monday, September 12, 2005
>> 8:52:13 AM
>> Lease Expires . . . . . . . . . . : Tuesday, September 13, 2005
>> 8:52:13 AM
>> Since we have two DCs so I am including both their ipconfig /all info
>> DC1 :
>> Host Name . . . . . . . . . . . . : dns01
>> Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network
>> Connection
>> Physical Address. . . . . . . . . : 00-03-47-CF-16-E3
>> DHCP Enabled. . . . . . . . . . . : No
>> IP Address. . . . . . . . . . . . : 192.168.88.10
>> 210.0.128.120
>> 203.198.23.208
>> 218.102.32.208
>> For DC 2:
>> Host Name . . . . . . . . . . . . : HKGDNS02
>> Description . . . . . . . . . . . : Broadcom NetXtreme 5751 Gigabit
>> Controller
>> Physical Address. . . . . . . . . : 00-13-20-01-9F-4B
>> IP Address. . . . . . . . . . . . : 192.168.88.7
>> The AD DNS domain name shown in Active Directory Users and Computers
>> is "mydomain.com", which is same as in the above ipconfig /all info.
>> I can see both domain controllers in the SRV folders exist in the DNS
>> in DC, except for under the location _msdc -> _pdc -> _tcp where only
>> DC1 (DNS01) exists.
>> For event logs the only thing I see as related to the problem around
>> the time when we were having problem is an event ID 8003, source
>> MRxSmb.
>> I certainly appreciate for your help all along. Thanks again, Ace.
>> YMan
> The big mistake I see, which can cause MAJOR ISSUES, is DC1's DNS config:
> 210.0.128.120
> 203.198.23.208
> 218.102.32.208
> You MUST Remove:
> 210.0.128.120
> 203.198.23.208
> 218.102.32.208
> It should ONLY show 192.168.88.10. Configure a forwarder on each server to
> these ISP DNS servers. Here's how:
> 300202 - HOW TO Configure DNS for Internet Access in Windows Server 2000 :
http://support.microsoft.com/?id=300202
> Then you should be good to go...
> Ace
Got it, Ace. I will give it a go and will let you know later.
Greatly appreciated your help. Many thanks.
