The wattage of the PSU depends on what else you have in your PC. The more components you have - the more power you need. Some full tower cases have up to 10 (ten) 5.25" expansion bays. You could have, I don't know, 5 hard drives, 3 optical drives, other drives, backup unit, up to 5-6 expansion cards, 4-5 fans an enthusiast CPU cooler, whatever. You could have dual CPUs and what not....
Regardless of that, I would suggest that you sell your 600Wt on ebay or craig's list or something and get yourself a 1000Wt. The way things are changing, power requirements are likely to continue to grow. With a big power supply you will be set for a long time; and should the need arise to add a couple of new hard drives or expansion cards or more case fans or whatever, you will not have to worry about power. Here's what I mean:
Most people upgrade their machines from time to time. However, some things stay the same for a long, long time. If you have a good PC case, for example, and it looks good enough for you, chances are you will not replace it for many years even if you replace everything inside it. I have had my Acer Open server tower for over six years now. The same is true about power supplies and (to a lesser extent) motherboards.
All other things, such as memory, CPUs, video cards, optical drives, etc., may come and go but the foundation remains.
That said, with a 1000 Wt PSU you can power everything and have power to spare. For example, should you decide to add another video card for physics to your SLI - no problem.
IMPORTANT NOTES:
1. PSUs never output the rated amount of power. Their efficiency is usually around 70-80%. This means that your 600Wt is effectively something like 420-480Wt
2. Once I installed my 550Wt PSU my monthly electric bill went up by approximately US$45. Imagine how much it would cost you to operate a 1000 Wt if your PC is on a lot.
3. I have a lot of stuff in my PC. I mean, my server case is fully packed to the point that there is almost no empty space inside it (and it is a huge case). I use a single card now. I would get a more powerful PSU if I went SLI or X-Fire myself.
