Heatpipe problem
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Heatpipe problem
Quick Question:
I really want a Lian Li V-series case. However, as anyone who has seriously looked at them knows, they have an inverted motherboard design. This isn't a problem until you add a motherboard with a heatpipe for the North/Southbridge into the equation. I have heard awful things about placing heat pipes in any other than the designed configuration.
My question is this: if I get a water cooling system for my case, can I safely replace the heatpipes on, say an ASUS P5W-DH Deluxe with a northbridge water block. The reason I ask is because the heatpipe is also connected to the voltage regulator, where the final heatsink resides, and I don't want to remove the whole heatpipe system and leave my regulator vulnerable.
Any help would be appreciated.
(Please don't tell me to get a board without a heat pipe. I know this is an option.)
Sponsored Links
Quote :
Quick Question:
oh...I think u'd have to remove the whole system, i dont think u can just bend it. BUT. If you remove the whole thing. u can cool the n.bridge with a zalman heatsink and find some old cheapo heatsink off a videocard and use it to cool the voltage regulator.
Reply to pengwin
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Heatpipe problem
There are 1239 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
