Building a quiet performing system with ASUS Tools
The Asus ASUS AI Life Style motherboards features some neat tools like Ai quiet and Q-fan2, even a 8-phase power design. For me these are important options as I am trying to build a quiet system without compromising in the systems performance. However, not all of the options are included on all of the ASUS motherboards.
Question 1 (general best noise reduction tool)
Q1 So my first question is which of these options (see quotes for more info) will contribute the most to building a quiet system? Note: tools like Ai gear are of less relevance to me. I am only interested in tools that regulate the voltages etc. automatically, which is not the case with Ai-gear.
Question 2 to 4(Ai Quiet)
Q2 If some of the Ai lifestyle serie owners could provide me with a little more information on HOW Ai quiet works I would be very pleased. The information about Ai quiet on the net is somewhat scarce.
Q3 Could someone clarify what is meant with "dynamically controls CPU"? Does it mean that it continuously AND automatically adjust the RPM of the CPU / case fan or does it regulate the fanspeed in like 3 steps (slow-medium-full)?
Q 4
Is Q-fan2 (always) included in Ai Quiet?
Question 5 (Q-fan2)
Q 5 (Q-fan2) In how many phases can Q-fan speed up or slow down a fan and can you manually set the thresholds?
Final question (ASUS board with finest noise redution tools)
What ASUS motherboard (+ Intel Conroe compatible board) is best suited for building a quiet system. Crossfire/SLI setup is not required nor is a overclockable board?
-Ray-
AI Quiet
The ASUS AI Quiet function dynamically controls CPU speed and reduces temperature and fan speeds when peace and quiet are what you desire.
Q 4
Question 5 (Q-fan2)
ASUS Q-Fan2
ASUS Q-Fan2 technology intelligently adjusts both CPU fan and chassis fan speeds according to system loading to ensure quiet, cool and efficient operation.
8 Phase Power Design
* Cooler and quieter system
* Longer components lifespan
* More stable and reliable under heavy-loading and overclocking
The ASUS 8-Phase Power Design provides highly efficient operation to generate less heat (at least 15°C (59°F)) than other conventional power solutions. It reduces input ripple current and output ripple voltage, which keeps CPU and power module from suffering the risk of high power stress. It has the advantages of quick transient response and stability, especially beneficial when CPU requires more current immediately under heavy loading or overclocking mode.
-Ray-
