Tom's Hardware > Forum > CPU & Components > Other Components > Logitech USB joystick problem
Forum CPU & Components : Other Components - Logitech USB joystick problem
I've got an (old, I know) Logitech Wingman Extreme, which worked for a good long while. It ends in a gameport connector, but came with a simple gameport-to-USB connector (nothing more than a female gameport on one end and a USB port on the other; no circuitry or anything like the generic connectors), which I used. I'm running Win2k.
At some point, it stopped working, and began giving me the 'Your gameport or gameport drivers are not properly configured. ...' error. The only thing I can think of that may have affected it is the soundcard I got from a buddy, and then removed after I realized that my motherboard's integrated sound sounded better.
Sponsored Links
I don't suppose the soundcard has a joystick port, does it?
And it's odd that an onboard audio would sound better than a dedicated daughterboard. What motherboard and soundcard are/were you using?
Reply to yourmothersanastronaut
The card was an SB Live! (has problems with crackling when multiple applications that can use audio are open, which is almost all the time with me :P), and the motherboard's an ECS K7S5A (and the whole computer is similarly outdated).
The soundcard did have a joystick port, and I tried plugging it back in and just connecting the joystick that way. It did indeed get rid of the error, but it still didn't recognize the Wingman (whether plugged into the card or into the USB port), or even a generic 2-axis 2-button joystick I've got lying around. So I pulled it again.
Reply to Legerdemain
Yes my dear friend CREATIVE sound cards had a gamming port to connect in the pentium 2 days .But onboard problem sound wierd.
Reply to rahul_cracker
I'm going to go see if the computer downstairs recognizes this joystick, so I can be sure it's not, in fact, the joystick itself. >.>
There are 1271 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
